JOHNTHOMAS
Super Member
- Joined
- Apr 14, 2008
- Messages
- 7,717
- Location
- Somerset, Ky
- Tractor
- F2690 4WD RTV X1140 MX5400 HST ZD1211
One of my blades is loose again. Tightened two of them with air impact wrench before last 5 hours mowing and todya after airing up the one flat tire AGAIN I was mowing and noticed not getting a full 72" cut. Outer blade was not cutting AGAIN. I've replaced the two washers, one bowed in the center, a couple years ago on one of the blades. About to try lock tite behind washer and against blade and retighten with air wrench but going to replace blades again and keep the current ones as spares and sharpen them.
Any of you having any issues with a loose blade on your decks????
Oh yeah, I was mowing fields that should have been bush hogged (thick heavy 4' high weeds/grass/small trees and ??) with F when the blade started slipping again.
