Shady oak
Bronze Member
I have a F2560 front mount mower with a 72 deck. Have had it for 16 years. This summer it started to lose power briefly once the fuel was at half and under. This only happens when going downhill, and generally while turning left. It gets worse as the fuel gets lower, but never stalls out, just sputters like its running short of fuel. Its like the machine picks up air, and then when you level out, away it goes.
If it was a safety switch the fuel level should not seem to impact it. If it was a filter then it should do it anytime, any fuel level. Would seem the same for the pump, or for something in the tank. The fuel pickup tube comes to mind, but the part I can reach is solid and doesn’t appear to have moved. I can’t see into the tank to the bottom and wondered it there is another part to the tube that could have fallen off, or come lose and the tube picks up air. The consistency of this issue is baffling.
Since the tube I can feel seems pretty solid, it does not seem possible it has a pin hole wore into it? Anyone have any idea, or even a schematic showing the path of the fuel tube in the tank?
Thanks.
Thanks.
