F24D Ring and pionion Backlash
   / F24D Ring and pionion Backlash #1
the_fitter
I'm installing a new rear ring and pinion gear set. How much backlash should there be.
Thanks Rick
   / F24D Ring and pionion Backlash #2
sorry don't have an answer for you. But wondering how much you ended up paying for the ring and pinion. And how hard a job is this.
Good luck
   / F24D Ring and pionion Backlash #3
.005-.010" is usually a good initial setting on any differential, to be adjusted up or down, depending on gear marking compound pattern.
Thanks for the info normde. I paid $695 for new set runningbird and if you have any doubts then it's best left to a mechanic.
2018 Freightliner Day Cab, Detroit Diesel, Auto (A52384)
2018 Freightliner...
2012 MACK GU713 DAYCAB (INOPERABLE) (A53843)
2012 MACK GU713...
Tradewinds Power Unit (A50120)
Tradewinds Power...
MISC PIPE WRENCHES (A53843)
MISC PIPE WRENCHES...
2016 Ford F-550 Ext. Cab Flatbed Truck (A52377)
2016 Ford F-550...
2016 RAM 5500 Bucket Truck - Cummins Diesel - Auto Trans - 4X4 - Altec AT41M Boom (A55218)
2016 RAM 5500...
