Burt_Mitchell
- Joined
- Mar 26, 2006
- Messages
- 7
I bought one of the Yanmar operation manuals for my F24D from Hoye Tractor. The manual is really helpful. I've learned quite a bit from it.
However, if you are troubleshooting an electrical problem the schematics could be a bit better so I decided to redraw the schematic in the manual. Most of what they had sorta makes sense but there is one component in the schematics for every F series that is not labeled and I haven't been able to figure out what the silly thing is.
If you have that schematic it's the component below the horn, above the fuses and to the right of the regulator. It has one line that is always hot from the battery, another line that is switched by the ignition (main) switch and a ground line.
The only guess I've come up with is that is some type of cutout relay that disables something while the starter is cranking.
Does anybody have a better guess?
