Grading F22d Steering box
   / F22d Steering box #1
nebuniram
Bronze Member
PNW
Yanmar F22d, Cat E70b
I have a question regarding my F22D with no power steering. I was told that the steering box is sealed on this tractor and do not need to add oil or service it. Is this true? I know the YM series need to be lubricated. Just want to be on the safe side. Thanks
   / F22d Steering box #2
It has a fill plug on it 1/4 PT.
Danny
   / F22d Steering box
Thanks Danny.
   / F22d Steering box
Alright, I found the fill plug, it looked like a newer plug and had teflon tape thred sealer on it. I unscrewed it and found grease inside the box, now I have heard that 90w oil needs to be in the YM's there but why is there grease inside my F22? At this point the steering works OK and I would really not want to remove the whole steering shaft assy to replace the grease with oil. I am thinking that possibly the steering shaft/pitman arm seal was leaky and someone just filled the box with grease? is the grease sufficiant lubrication for the bearings in there? What would you guys recomend?
   / F22d Steering box #5
I would fill it with, (add), 140w until it runs out the hole.
   / F22d Steering box
Norm, I was thinking the same thing just wasnt sure. I think I will just fill it with gear oil, Im hoping it will mix OK with the grease thats in there. The grease looked golden and not black/pasty so hopefulley all should be well. FYI its much easier to check the fluid on the F' series tractor, all you have to remove is the bottom cover below the dash and the fill plug is in front not in the back like the YM's. Thanks
-Joe
   / F22d Steering box #7
That sounds like some of that JD "Corn Grease", like someone put it in there exactly because it was leaking. I think I'd leave it alone if it's working OK, unless you want to pull it and reseal it.......
   / F22d Steering box
Well I ended up filling it with /140wt gear oil, so far no leaks from the seal. I also lubed all the steering joints and steering feels easier to turn. Thanks for the replys
2003 VIKING  CEMENT MIXING TRAILER (A52472)
2003 VIKING...
1977 GMC GENERAL TANDEM AXLE DUMP TRUCK (A52577)
1977 GMC GENERAL...
2006 UTILITY VS2RA 53 FT REEFER TRAILER (A52577)
2006 UTILITY VS2RA...
PAIR OF PIPE RACKS (A52472)
PAIR OF PIPE RACKS...
JLG MANLIFT (A52472)
2001 Nissan Frontier Crew Cab Pickup Truck (A51692)
2001 Nissan...
