F215 Instrument panel
   / F215 Instrument panel #1
nevis
England
Yanmar F215
I'm new to Yanmar and I've just bought an immaculate F215 which does everything great. But the only instruments that work are the Tachometer and the parking brake light - fuel guage, temp gauge, and all other red lights don't do anything.
I assume my first step is the fuses but to save me taking things apart unecessarily can someone tell me where the fuse box is? Or any other suggestions ( I think the panel may not be original as Yanmar 255 is written on the tach). Thanks
   / F215 Instrument panel #3
Post up a pic so we can see how it looks and we'll probably be able to help better. On my 1602D, it's on the left side, below the instrument panel.
And Welcome to TBN!
   / F215 Instrument panel #4
And Welcome to TBN!
   / F215 Instrument panel #5
I will have 3 F215s later this week here
email me orcall and I will go over it with you.
Thanks Ernie
www.ernies.net
   / F215 Instrument panel #6
Thanks Ernie
www.ernies.net
   / F215 Instrument panel #7
Since all the problems are with electrically operated gauges, I'd suggest bitting the bullet and pull the instrument panel. Could be the instrument cluster is unplugged.
While I have a nice tractor and all is working great, I had a problem with one of the gauges and when taking a look I found that the instrument cluster had been replaced. They didn't just unplug everything but cut all the wires. After some work found a bad connection for the circuit I was having trouble with.
Sorry Ernie, I know this wasn't your doing.
   / F215 Instrument panel #8
   / F215 Instrument panel #9
Firewall, clutch side above starter. Remove side cover.
Buck
   / F215 Instrument panel #10
Buck
2008 VE 500 BBL FRAC TANK (A53843)
2008 VE 500 BBL...
2005 Superior Trailers VT130 T/A Vacuum Trailer (A51692)
2005 Superior...
2018 Lexus IS300 Sedan (A51694)
2018 Lexus IS300...
2016 Atlas V4 Towable Light Tower (A51691)
2016 Atlas V4...
VERMEER NAVIGATOR S3 D10X15111 DRILL (A51406)
VERMEER NAVIGATOR...
