F16D Gear Ratio
   / F16D Gear Ratio #1
ircked
Yanmar F16D
Any one know what the front /rear gear ratio is for a F16D Yanmar?
   / F16D Gear Ratio #2
Good question. I've been trying to find a manual since I bought mine. I know the 195D has the same engine and I would be willing to bet the gears are the same.
Do you know how to get a rough estimate? Place in 2wd and jack up the front in the air enough so only 1 wheel is off the ground. Then, you make marks on the wheel and front drive shaft and then spin the wheel one revolution and count the number of times the driveshaft revolvles. Use a grease pencil to make easily visible marks. This will get you close.
2013 RAM 4500 (A50323)
KONE CRANES SMV-25-1200 HEAVY LIFT FORKLIFT (A52472)
KONE CRANES...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2016 VOLVO VNL300 TANDEM AXLE DAY CAB (A52576)
2016 VOLVO VNL300...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A51572)
2007 Isuzu FTR...
Landoll Hauloll (A52748)
Landoll Hauloll...
