F series hydraulic quesiotn
   / F series hydraulic quesiotn #1
Barnbuilder
Waxhaw, NC
Bobcat A300, Kubota F3680, JCB 212S sold
If an F series and the aux hook ups would I be able to use them for a dump trailer to pull behind it?
   / F series hydraulic quesiotn #2
Not sure if that helps.....I have hydraulic only up front for the snow blower. And i rigged up a hitch to move my trailers around.
Edit: You mean hydraulics to operate the trailer? Haven't had the need to do that, but don't see why it wouldn't work.
Yes. If I had a hydraulic dump trailer to pull behind mower, would the mower itself have enough fluid/pressure to operate the cylinder? Is that questioned better?
   / F series hydraulic quesiotn #4
it'll do it. how fast, depends on ram size. 200 psi will raise it and the charge pump on my F2690 generates 3200psi
2012 BMW 328i Coupe (A51694)
2012 BMW 328i...
2024 Kubota L3302 4x4 Tractor with Backhoe (A51573)
2024 Kubota L3302...
IMPORTANT PLEASE READ!!!! TERMS AND CONDITIONS (A51573)
IMPORTANT PLEASE...
LMC LOT NUMBER 139 (A53084)
LMC LOT NUMBER 139...
Bushog 3 Point Hitch Wood Splitter (A51573)
Bushog 3 Point...
2015 Freightliner Cascadia 125 Truck, VIN # 3AKJGEBG5FSGD4138 (A51572)
2015 Freightliner...
