F series deck minor wheel issue
   / F series deck minor wheel issue #1
RBsingl
Bronze Member
Deere 955 Kubota F2690
At 90 hours on my F2690, I had the first minor issue. I have the 72" rear discharge deck and I noticed one of the front deck gauge wheels wasn't running true. I knew I hadn't hit anything hard enough to damage it and the problem was 3 of the 4 nuts holding the two wheel halves together on the hub were very loose and the fourth was entirely missing.
Fortunately an easy problem to solve, I replaced the missing nut and used Loctite on all four of the bolts. Then I checked the other side and 3 of the four were starting to loosen so all four of those also got the Loctite treatment.
This was likely a supplier issue of not properly tightening the nuts down sufficiently in the first place but the Loctite should prevent future problems.
Otherwise, I love the operation of the Kubota and it definitely mows more quickly and cleanly than the 72" midmount deck on my Deere 955 which now gets to keep its loader mounted all of the time since it doesn't do lawn duty.
Rodger
Lonestar Panel w/ Feed Bunk (A49339)
Lonestar Panel w/...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A45678)
2012 VOLVO VNL...
John Deere 275 Disc Mower (A49251)
John Deere 275...
2018 Schulte FX107 84in Rotary Cutter Attachment (A46683)
2018 Schulte FX107...
2004 Delta 6ft. 6in.x 16ft. GN Steel Livestock Trailer (A49339)
2004 Delta 6ft...
2015 Nissan Sentra Sedan (A46684)
2015 Nissan Sentra...
