F-550 GVWR?
   / F-550 GVWR? #1
56FordGuy
Sumner county, TN
I was wondering if anyone here might have a sheet that lists the various GVWRs available for a 1999, 4x4, diesel F-550 with an automatic transmission. I don't know what the gear ratio is.
I'm considering purchasing one, but the lot was closed tonight when I went by to look at it. Just wondering how much of an increase it would be over my F-350 with a 12,500 lb GVWR.
   / F-550 GVWR? #2
1999 Ford Super Duty F-550 Reg Cab 141" WB XLT 4WD
Specs
All new 1999 Ford Super Duty F-550 specifications include engine specs, transmission, drivetrain, bodystyle, color choices, standard features and options, and more. These vehicle specs will arm you with the knowledge you will need to shop for or compare cars.
EXTERIOR
Aero halogen headlights
Argent grille w/chrome surround insert
Black door handles
Black manual fold-away trailer tow mirrors
Chrome front bumper w/lower center trim
Fixed interval wipers
Roof clearance lights
Solar tinted glass
INTERIOR
(4) air registers w/positive shut-off
11.5" day/night rearview mirror
Auxiliary pwr point
Back panel storage provisions-inc: hanging storage bin, storage trays, utility hooks
Black vinyl steering wheel
Cigar lighter
Color-keyed carpet full floor covering
Color-keyed cloth sun visors-inc: LH retainer strap, passenger vanity mirror
Color-keyed door trim panel-inc: soft armrest, grab handle, reflector, upper vinyl insert, carpeted map pocket
Color-keyed instrument panel w/dual cupholders
Color-keyed molded cloth headliner
Color-keyed scuff plates
Dual front color-keyed coat hooks
Dual map lights
Electronic AM/FM stereo w/cassette-inc: digital clock, (4) speakers
Front door operated dome lamp w/time delay off
Front passenger assist handle
Gray fabric back panel cover
High series cloth 40/20/40 split bench seat-inc: armrest, storage, outboard seating position integral headrests
Inside hood release
Instrumentation-inc: tachometer, voltmeter, trip odometer, oil pressure/ coolant temp/fuel gauges, indicator lights
Underhood service light
MECHANICAL
(2) front tow hooks
(6) 19.5" x 6.0" 8-hole styled steel wheels
(6) 225/70R19.5F all-season SBR BSW tires
11,090# maximum payload
141" WB
17,500# GVWR (5600 front/13,500 rear), springs (5600 front/13,500 rear), axles (6000 front/13,500 rear)
2-speed transfer case
36 gallon fuel tank-inc: auxiliary fuel tap
4-pin trailer tow wiring
4-speed electronic automatic transmission w/OD
4.88 rear axle ratio
6.8L (415) SOHC SEFI V10 engine
72 amp/hr (650 CCA) maintenance-free battery
95 amp alternator
Four wheel drive
Front stabilizer bar
HD gas shock absorbers
Manual locking front hubs
Mono-beam front axle
Pwr 4-wheel anti-lock disc brakes
Pwr steering
SAFETY
4 wheel anti-lock brakes
Color-keyed safety belts w/adjustable D-rings
Driver air bag supplemental restraint system
Dual-note electric horn
2011 Ford E-250 Cargo Van (A42742)
2011 Ford E-250...
2012 Ford Econoline E-350 XLT Super Duty (A44500)
2012 Ford...
2010 Toro Reelmaster 5610 Fairway Reel Mower (A42744)
2010 Toro...
New/Unused Self Dumping Hopper (A44391)
New/Unused Self...
JLG 60H BOOM LIFT SN:22756 powered by Deutz dieel engine, equipped with 60ft. Platform height, (A40022)
JLG 60H BOOM LIFT...
2011 John Deere Z Trak Pro Z925A 60in Zero Turn Mower (A42744)
2011 John Deere Z...
