Extra valve for BX2200
   / Extra valve for BX2200 #1
tmacie
Brattleboro
Kubota BX2200
Hi All,
I have a Kubota BX2200 that I would like to add an extra valve/function to. I've looked at the threads already posted about doing just this BUT my situation has a little twist.
The tractor has an early LA211 loader with the loader valve that stays on the loader when its removed. All of the threads posted refer to using the PB port on the loader valve. Since my loader valve goes with the loader, and I don't want to keep the loader arm on the tractor like some people do, I'm not sure where/how to plumb the valve.
I would like to be able to use the new valve with the loader on or off.
Any thoughts or ideas would be appreciated.
Thanks,
Travis
   / Extra valve for BX2200 #2
I've done a remote on a bx1500 which also has the valve that stays with the loader, I don't have pictures but it's plumbed the same as if the loader valve stayed mounted.
PB hose that plugs into the loader valve going to the 3pt now goes to the aux valve, PB on the aux valve now goes to the 3pt
Tank/return is T'ed into the hose that doesn't get plugged into anything when the loader is removed.
I ran the hoses from the rear remote back up to where the qc for the loader valve are, was just easier then trying to mess with the factory hard lines.
2014 Ford F-150 Ext. Cab Pickup Truck (A50323)
2014 Ford F-150...
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
2011 Cadillac DTS Sedan (A50324)
2011 Cadillac DTS...
McDon 75D Flex Draper Head (A52349)
McDon 75D Flex...
12in Backhoe Bucket (A52748)
12in Backhoe...
2016 Ford F-450 Cab and Chassis Truck (A51692)
2016 Ford F-450...
