Tire Selection Extra set of tires
   / Extra set of tires #1
brunswickboy
Moncton
NH T1110
Hi all
I have a T1110 NH tractor HST 4X4 and have turf tires on it. Back 29X12.5-15 and fronts 20X10.00-10. I would like to have a second set of Agricultrual or industrial tires and rims that i could quickly swap out for working on my wood lot. I am having a difficult time finding a set , and am aware that i have to be careful with tire size and a 4wd. I have two questions,
1. If I had just had a set of Ags or ind of the same size for the rear and left my turfs on the front, would that work?
2. If I needed to change my front and rear sizes in order to get the proper ratio, how would i find that out?
   / Extra set of tires #2
We can help you, Call Ed at 800-631-1955, Mon-Fri, 8am-5pm EST.
   / Extra set of tires #3
I don't know if this is factual but site lists turfs and industrial tires are the same size. If true this answers question 2. However, as for question 1 even though the tire sizes may be the same numbers the industrial and turfs may have different diameter roll out and not be compatible to mix and match just fronts or rears.
http://www.delclayfarmequipment.com/pdf/Compact.pdf
Ed
I will call tomorrow.
Jake
Ed
I live in Canada, so the 1-800 doesn't seem to work.
Jake
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
(9) 2 PLUG VALVES (A52472)
(9) 2 PLUG VALVES...
2015 FORD F-150XL SINGLE CAB TRUCK (A51406)
2015 FORD F-150XL...
2006 V.E. ENTERPRISES 130 BBL STEEL VACUUM TRAILER (A52472)
2006 V.E...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A52748)
NEW 2024 LOAD...
