Extra Engine Cooling Fan
   / Extra Engine Cooling Fan #1
maujer422
Springfield, Ohio
Power Trac 422
What are your thoughts? On the 422 the oil cooler is right over the hot engine and exaust. I bought a 10" electric fan, my first thought was to mount it on the back of the hood to pull out. [exaust blows out to the right] Then I thought I should mount it on the left side and blow air onto the engine, but that is the side that gets most of the grass from the mower I don't know if this would create a problem. Should I put in a partial heat shield to block some of the hot exaust from the oil cooler, after I install the new fan? Should this fan run all of the time? I think summer yes, winter no? The fan will push or pull.
   / Extra Engine Cooling Fan #2
Is there a problem with overheating? or a perceived problem?
When I mow the oil tank gets very hot, you can't touch it more than 2 or 3 seconds, that is with the fan on. That is why I was thinking of puting on the extra fan to help get the heat out of the engine compartmment so the oil cooler can do a better job.
DMI 3200 Side Dress Bar (A50514)
DMI 3200 Side...
2000 Polaris Sportsman 50 (A50515)
2000 Polaris...
1000 gal Poly Tank (A50515)
1000 gal Poly Tank...
2010 Dodge Grand Caravan SE Van (A50324)
2010 Dodge Grand...
2012 ISUZU NPR 18 FT FLATBED (A52141)
2012 ISUZU NPR 18...
(10) 7 x 9 Treated Posts (A50515)
(10) 7 x 9 Treated...
