extension for rear implement
   / extension for rear implement #1
jam2004
central NJ
Kubota BX 2230
When pulling my manure spreader, the control levers often make serious contact with the 2230's lift arms (in up or down positions). Are they any pre-fab extensions out there that will give me more space between the hole in the back of the tractor and the hole in the tongue of the spreader? It's particularly bad when the spreader is on higher ground than the tractor.
   / extension for rear implement #2
I don't know of any extensions other than making a longer draw bar or even easier would be to have the tongue on your spreader lengthened. That way all other implements don't need to have adjustments.
Any guy that knows how to weld pretty good can do.
murph
   / extension for rear implement #3
Can you adjust the control levers? If not, can they be modified? That is probably easier and safer than fiddling with hitch strength and load geometry. Not to mention the PTO if it is PTO driven.
</font><font color="blue" class="small">( Can you adjust the control levers? If not, can they be modified? That is probably easier and safer than fiddling with hitch strength and load geometry. Not to mention the PTO if it is PTO driven. )</font>
Non-PTO. Thanks for the input.
   / extension for rear implement #5
Jay here;s a thought for you, instead of lengthening the draw-bar add a receiver tube like we did. Then you can use 2 X 2 square tube to make different length draw-bars, When finished you can remove them and not have to worry about banging you shins.
   / extension for rear implement #6
I like Pine Ridge's idea. Also, could you take some flat stock and weld it over your existing hitch and then drill holes? Not sure if you have the access to stuff to do that, I know I don't, unless I pay for it /forums/images/graemlins/blush.gif
Hmmm just noticed you said "pre-fab". Crud. Is there a place that sells replacement drawbars where you could get a longer one for a different tractor with fitting heigth and width dimensions?
</font><font color="blue" class="small">( I like Pine Ridge's idea. Also, could you take some flat stock and weld it over your existing hitch and then drill holes? Not sure if you have the access to stuff to do that, I know I don't, unless I pay for it /forums/images/graemlins/blush.gif
Hmmm just noticed you said "pre-fab". Crud. Is there a place that sells replacement drawbars where you could get a longer one for a different tractor with fitting heigth and width dimensions? )</font>
Yes. I like both ideas. However, I don't have "access" nor skill to do that stuff. Thank you both. Perhaps I can drive my Kubota on the PA Turnpike and Pine can take care of it. Nice shot of the NH.
   / extension for rear implement #8
Send me tha parts the cheapest way possible and I'll do the welding for free. PM me for an address.
2007 STERLING T/A DUMP TRUCK (A51406)
2007 STERLING T/A...
4"x8' Treated Post, 36 Piece Bundle (A52384)
4"x8' Treated...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
2008 CATERPILLAR M322D MOBILE EXCAVATOR (A51406)
2008 CATERPILLAR...
