Extension for 3 pt arms
   / Extension for 3 pt arms #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
I have been using a Ford 800 and MF 65 for about 35 yrs.Just jumped up to a Kubota M6800 4wd with 16.9x30 rear tires.My problem is even with the little arm extensions out I can barely fit when trying to attach an implement.The same implements are a breeze with my older tractors.I see on Nothern tool site ,I think the name is Paul's quick hitch ends and was wondering if you think these would help by giving me a tad more arm length so I can hook up a little easier.Anybody else seem to have this problem ?
   / Extension for 3 pt arms #2
Pat's Quick Hitch will give you about 4" extension. Available for Cat 1 and Cat 2 hitches. Is M6800 Cat 2?
Will your Lower Links have to remain extended to give you the 4" with Pat's? I do not know.
You can buy Pat's from the T-B-N STORE. See top of page.
   / Extension for 3 pt arms #3
jeff9366 has the solution. ^^^^^
Technically, the name is Pat's Quick Connect.
   / Extension for 3 pt arms #4
For what it's worth, I am on my THIRD tractor with the ORIGINAL Pat's quick hitches.
[I do toss a new coat of paint on them now and then, mainly when I move them to a new tractor] ;)
For top link - Brian even asked which VERSION of Pat's I had because the length had changed over the years.
I told him 'circa 1998' and he was able to craft a top link with that consideration in mind. It has the perfect reach for the 3046r/cab.
fit-rite hydraulics is his site [or search for him here on this site].
(Thanks again Pat & Brian for making great products!)
JBI Spray Booth Air Filtration System (A42742)
JBI Spray Booth...
2017 Komatsu PC138US-11 Excavator (A42203)
2017 Komatsu...
2017 Toro Zmaster 7000 72in Rotary Mower (A44572)
2017 Toro Zmaster...
2012 GALYEAN 130BBL VACUUM TRAILER (A45046)
2012 GALYEAN...
2015 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A43003)
2015 FREIGHTLINER...
2010 International 4300 U3-HK Hooklift Truck (A44571)
2010 International...
