Extended LIfe Undercarriage
   / Extended LIfe Undercarriage #1
Hogdaddy
KY
09 5058M
I'm looking at a 550H LT CASE with what the guy that owns it describes as a extended life undercarriage. What brought the subject up is that the sprocket has large, flat(2-3") teeth. I had never seen that before. Is that a characteristic of those types of undercarriages and what else can I look for to tell if it is extended life?
   / Extended LIfe Undercarriage #2
I thought the extended life feature was just the pins. They are either harder steal that doesn't wear as fast, or they have a lubricant inside them and designed in such a way that they roll and even out the wear all around instead of just one side. I didn't think the sprocket was any different. They should all have the flat ends to the teeth. When they wear down to points, it's long past time to replace them.
Drawback to extended wear is the up front cost and the replacement cost. The pins are the most expensive part of the undercarriage, and the hardest to replace. You can't do it yourself, and a shop that can will cost quite a few grand to do the job, once you either get the tracks in there or haul the machine there for them to remove the tracks and do it. My tracks weigh well over a ton, so it's not a simple task of taking them off, loading them on the trailer and then putting them back on. I've done it, and each step is an all day project.
Eddie
   / Extended LIfe Undercarriage #3
The pins should be sealed and oiled and it should have larger bushings. A case dealer should be able to give you the specs or you could look them up on line possibly. I think the sprockets might be common to both a new regular case undercarriage and an extended life one only due to the chain pitch are the same when I looked them up on another case dozer.
You might want to try heavy equipment forums. I know I have seen thread over there about these systems.
I know what they are but don't know anyone around here even with a Case dozer anymore.
Well, I bought the dozer yesterday, We shall see how it lasts. I'm pleased though, it only has 1300 hours on it.
Thanks for the replies!
   / Extended LIfe Undercarriage #5
Well if it was taken care of, it's just broke in, you should get a lot of use out of it before sinking any money into it.
Hope it works out for you.
UNUSED FUTURE QUICK ATTACH CURVED LOG GRABBER (A51244)
UNUSED FUTURE...
2009 FORD E-350 VAN (A50324)
2009 FORD E-350...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
RoGator 844 sprayer (A50490)
RoGator 844...
2014 Gillig 31+56 Low Floor Passenger Bus (A50323)
2014 Gillig 31+56...
Roose Hog Cart (A50515)
Roose Hog Cart...
