Extended iMatch Hook and iMatch Adjustable Hook Pins
   / Extended iMatch Hook and iMatch Adjustable Hook Pins #1
kennyd
Advertiser
Westminster, MD
John Deere 3720 CAB/TLB, JD455
KBOGH/BoltOnHooks LLC is proud to introduce the Extended iMatch Hook for the John Deere iMatch Quick Hitch system with the adjustable top hook. This new hook extends out 5/8" over original hook making implement changes faster, easier, and in some cases even possible. This replacement hook DOES NOT fit other low cost imported hitches from Harbor Freight and other sources.
Also available is the iMatch Adjustable Hook Pins. These pins will allow you to remove the existing bolts that holds the hook onto the iMatch frame to facilitate easy height changes with no tools required. These pins also add in a bit of extra "slop" or "play" that will let the implement attach easier in most cases. 100% made in the USA of the finest materials available and zinc plated to resist rust and corrosion
Available on the iMatch Accessories Page.
2025 CFG Industrial MX15RX (A50123)
2025 CFG...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
2016 Kubota SSV75 Compact Wheel Loader Skid Steer (A51691)
2016 Kubota SSV75...
2013 WABASH DVCVHPC 53FT DRY VAN TRAILER (A53426)
2013 WABASH...
2023 PETERBILT 579 TANDEM AXLE SLEEPER (A53426)
2023 PETERBILT 579...
2019 Chevrolet Tahoe Multipurpose Vehicle (MPV) (A52377)
2019 Chevrolet...
