Explain hydraulics to me
   / Explain hydraulics to me #1
ICGREEN
Pendleton IN
JD 3520
Will someone please explain to me what SCV stands for. Also if I had a 2 spool SCV what would I have? What about a 5 spool SCV. Thanks
   / Explain hydraulics to me #2
SCV = Selective Control Valve
Singles make things like my tilt bed trailer operate in a simple method like up-down.
Doubles can operate things like my front end loader two ways like up-down AND operate the bucket to dump and tilt up.
Here's a link to a good explanation of hydraulics and how they work.
http://www.howstuffworks.com/hydraulic1.htm
I hope this helps. /w3tcompact/icons/smile.gif
   / Explain hydraulics to me #3
As Gary said SCV stands for Selective Control Valve. Each valve is made up of a valve body (which the hoses attach to) and a moveable internal "spool". When you move the control lever the spool moves inside the body and changes the amount and direction of hydraulic fluid flow. There are two basic types of spools- "single acting" and "double acting". A single acting spool has one input and one output and moving the spool changes the amount of fluid through the spool. A single-acting spool can only drive a cylinder one way. A double acting spool has one input and two outputs. Moving the spool not only changes how much fluid flows but also which output it goes to. Thus, a double acting spool can drive a cylinder in both direction. Pretty much all of the valves on a tractor are double acting. If you want to control more than one motion then you just parallel more valves (and spools). Your loader has two spools- one for up-down and one for tilt. A 5 spool SCV could control 5 motions.
Dave
2008 FORD RANGER SINGLE CAB TRUCK (A51406)
2008 FORD RANGER...
2015 Peterbilt 320 Garbage Truck (A52377)
2015 Peterbilt 320...
(APPROX 60) DIAMOND TREAD DBL AXLE FENDER BACKS (A51247)
(APPROX 60)...
2012 Ford F-450 Knapheide Service Truck with Liftgate (A51692)
2012 Ford F-450...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
Manac Walking Floor Trailer (A50322)
Manac Walking...
