Comparison experience level
   / experience level #1
Rockman
Bronze Member
Franklinton NC
kioti ck20 gear
I am just curious as to the experience level of compact tractor buyers. I am also curious as to how much if any training your dealer provides to buyers with little or no experience.
   / experience level #2
I would think it is a widely variable group, some with lots of experience, some with no prior experience at all. I would suspect the instruction is provided on a limited "needs basis". Most dealers will take you thru operation if you ask them to.
   / experience level #3
I think the tractor dealer would assume that you would know how to operate a tractor if you where there to buy one. No different than a car dealer would be.
   / experience level
That is the point, I'm betting a large percentage of compact tractor buyers have little or no experience. I'm also betting a large percentage of tractor breakdowns are due to operator abuse/error due to lack of training.
I am not trying to find fault with ANYONE, but after being a member of this forum for 4 years, it seems alot of owners are learning alot of lessons the hard way.
   / experience level #5
...it seems a lot of owners are learning a lot of lessons the hard way.
That's a good point. Some of us got our first compact tractor experience
after we got our first gray hairs. That usually means we bought a used
tractor and got little or no help with learning how to use it correctly,
safely, and without learning too many lessons the hard way. I wish I had
some help with my first CUT, back in the late 90's. How many guys (or
gals) get their first tractor from a dealer?
I have now owned 15 and most of the guys I sold them to were newbies.
Now that I have learned a lot (some things the hard way), I have found
myself in the position of giving lots of advice and training. Some guys
want to figure it out on their own, however.
Of course, some fortunate TBNers grew up on a farm, so their dads gave
them lessons at a very young age, no doubt.
   / experience level #6
I totally agree. I was raised around tractors. For those that are new to tractors the only hope would be an a friend or relative that is knowledgeable about tractors. I think a quick lesson from a dealer on the lot is just not enough.
   / experience level #7
Most of the break downs lately seem to be electrical of some sort. Safety switches and battery main connections hold the lead.
Don't see how that could be "due to lack of training"
   / experience level #8
A lot of times also what happens is relatives or friends of tractor owners will be talking about how they need this done or wished they had a tractor they could do this and that around the house and before the tractor owner realizes he has offerd to let that person come barrow his tractor assuming this person knows how to operate one only later to find out when his friend or Kin brings it back broken in some way:cool: and you ask what happen the reply is he didn't know that the tractor only had a 1 wheel brake and spun the tractor around and took out the headlight against the corner of the barn.:confused2: and then you have to explain to him each pedal was for separate left and right brakes and if you press them both at same time you stop evenly,:confused3: its the little small things like this that if first time users can't figure out then they sure don't need to be on a tractor, But instead with this little bit of experience in operating a tractor he decides to go gets one of his own and this is when the real trouble begins,:D
   / experience level #9
I grew up driving simple, uncomplicated tractors like Ford 2, 9, 8N, 600 tractors then got away from tractors for a while in the late 70's then started using the more modern 4WD with all the bells and whistles in the 80's. I can only imagine how overwhelming it is for someone with no experience to be handed a new tractor with little more than a set of keys and maybe a brief explanation of what does what. I am surprised no more mechanical and physical damage is done. It would be nice if a program similar to that offered to new ATV owners was available to new tractor owners.
My skill level is still no more than adequate.
   / experience level #10
If most would take the time read booklet also attachment booklet and understand they would have fewer headaches..lets not for get common sense/gut feeling.
Also agree most dealers will do show thru also talk about,and feel the new owner has clue.
71064 (A49346)
71064 (A49346)
UNUSED FUTURE 71" CLIP ON FORK EXTENSIONS - PAIR (A51244)
UNUSED FUTURE 71"...
1272 (A50490)
1272 (A50490)
2013 PETERBILT 367 (A52472)
2013 PETERBILT 367...
2020 Cat 299D3XE Skidloader (RIDE AND DRIVE) (A50774)
2020 Cat 299D3XE...
2014 Chevrolet Equinox SUV (A50324)
2014 Chevrolet...
