experience captivation/cavitation when dumping heavy material
   / experience captivation/cavitation when dumping heavy material #1
alltherage
Western NY
2011 Cub Yanmar EX2900. 1939 Farmall A, 1940 Farmall H, 1959 Oliver 770
Have any of you experienced this with the cub yanmars? When I curl to dump dirt its fine, but when dumping heavy stone the bucket will start curling down and then stop for a couple seconds and then resume. I don't have any problem lifting. I've read about it and its called captivation or cavitation (can't seem to get a straight answer) and essentially involves fluid not catching up in time to the bucket movement caused by heavy loads. Is this normal for these tractors??....running at higher rpm does help but doesn't eliminate.
   / experience captivation/cavitation when dumping heavy material #2
It is cavitation. Essentially air getting trapped in the oil. Doesn't
Sound like a huge problem.
2015 Cadillac Escalade ESV Platinum AWD SUV (A50324)
2015 Cadillac...
2020 KUBOTA RTV...
John Deere Quick Attach Pallet Forks (A50514)
John Deere Quick...
International 1066 2wd tractor (A52128)
International 1066...
Hays LT1 Tender (A52128)
Hays LT1 Tender...
Unused Delta Crash...
