longjohn79
Bought a used Exmark zeroturn. 1000 hours, owner said he changed hydro fluid and then it wouldn't move. I purchased as is cheap. I tried bleeding air and all it will do is drive one tire and then after a while of holding both sticks forward or reverse is that it will switch which tire is moving. The other tire in those cases can be stopped by hand or doesn't turn at all. Looks like pumps where changed or at least removed and messed with.
Does anyone know procedures I can use to test to see if pumps are good? If drive Motors are good? Fluid is correct and full, and I have ran it for 10-15 minutes at a time with wheels raised, have cracked hoses to try and bleed, and also backed off the hydro filter to let fluid run out to help bleed air.
Any ideas or tests or checks are greatly appreciated. I found an operator manual but now am also looking for a shop manual.
Thanks!
Thanks!
