Exmark pto
   / Exmark pto #1
4720 OWNER
WEBSTER, MN
JD 4720
Have an Exmark lazer z, 44" commercial deck.
Sharpened the blades and went out in the pasture to cut some of the thistle down. Brought it back in and shut down and put in the barn. Next day, took it out to do some lawn mowing. Hit the pto and nothing happened.:mad:
When i put it away was running like a top, mowed thistle like it was not even there. Nothing done to it in the mean time. Any advice from out there??:confused:
Still working on the Toro Groundsmaster. Had the center shaft rebuilt after the splines to the pulley got tore up. $350 for the parts and labor!!!!:eek:
   / Exmark pto #2
Is the pto belt still attached? Does the pto clutch "click" when it's engaged?
   / Exmark pto #3
I would be looking for a safety stuck, or a wire out / cut etc.
Just going to be some basic troubleshooting, see how far you have power, cycle all switches several times, tap the relays, check the couple fuses (if it is like a lazer Z they hang in the middle there.
2011 FORD F-450 (A52472)
2011 FORD F-450...
2 pair -st205/75r15 radial trailer tires (A53421)
2 pair...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
2015 FREIGHTLINER CASCADIA DAYCAB (A53843)
2015 FREIGHTLINER...
Pallet of Miscellaneous Mini Excavator Attachments (A52377)
Pallet of...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A52377)
2009 Trail King...
