ExMark CT vs. Toro Z Master
   / ExMark CT vs. Toro Z Master #1
JimMorrissey
Veteran Member
Southern Maine (now)
'05/'06 L39 TLB
Any experts care to voice their opinion....Both are very nice machines. Any help would be appreciated. I've driven them both and like both. Like both dealers too.
I was looking at residential models, but then as I looked around this place I realize that within a three years or so when we build in the back lot I will have substantially more lawn to mow, and there are other areas that I might reclaim to lawn. My wife is starting to come around /forums/images/graemlins/smile.gif and I've got the green light for some more green.
OK...not much action here. Does anybody know anything about the Toro Z Master, forget any comparison against the ExMark.
I wish there were some professional magazines on the Web that did ZRT "shoot outs" and such.
   / ExMark CT vs. Toro Z Master #3
Jim, not much help here except to say that I have been looking at the Toro Z400 48”with the 18 hp Kohler motor. With out any dickering it was quoted at $5400 before tax at a small local dealer here. If you don’t have one, I have the Z Master booklet with all the specs and would be happy to look up anything you want.
MarkV
   / ExMark CT vs. Toro Z Master #4
Convinced the wife that more green requires "more green"? /forums/images/graemlins/grin.gif
Don't know much about the Toro machines, but I think Z-Master actually applies to several models [I'm thinking even some of the out-front decks]. Can you post the model number?
Anyway, someone made a very good observation on another thread that once you get into the commercial units you will not be disappointed with quality regardless of brand [let's say enough area (like you) to warrant a rider, but not the abuse for a bush-hog] . There will be regional "bang for the buck" influences as well as dealer preferences. And there will be plenty of variation in features; possibly even one or more is important to you; but quality should be good.
That being said, there is now a real gray area between commercial and home units, some putting "commercial" parts on "home" type frames and vice versa to stay under 5K [not necessarily bad; one may be perfect for you]. Even decks can be a gray area, I saw a couple fab decks that didn't impress me more than some stamped ones. It's all around "in-between" design is one reason I liked the Z-Force, everything looked to be designed around it's target 2-3 acres, but plenty others fit this description as well [my requirements seemed out of this scope].
Using reverse logic [and barring the <1acre and nice flat lawn] on the units I seen with EZT, I'd say the IZT is nearly a no-brainer. But if you're looking to spend around the 5K, I'd look for a pump/motor configuration [most of these are high quality and this configuration generally has superior cooling over integrated].
BTW: if you Google a few comparisons, you will stumble across a garden web [I never did get their registration to work, but you can still read all the posts] and a turf web that probably has some insight to your choices. Most of the users seem to be either lawn care professionals, or those who have sq-ft instead of acres, but both bring up weaknesses you wouldn't think of.
Happy Mowing! /forums/images/graemlins/cool.gif
Mark,
Thanks. I looked at the same one...and have the brochure. Nice machine. There is little to no discussion on Toro ZRTs in this section.
   / ExMark CT vs. Toro Z Master #6
Jim, I have an Exmark, and it's been trouble free for over a year. I really liked the controls better, I felt like they were a little more progressive and easier to use. The quality is there and my dealer has been great. I bought the mulching kit ($169!!!!!) and used it at the end of last year, but I'm going to put the regular blades back on because I think it gives a better cut. I'm sure you'd be happy with the Exmark........
/forums/images/graemlins/smile.gif Got the CT. Sweet machine. -See "The Winner is eXmark" post.
Kubota KX91-3S2 Mini Excavator (A52377)
Kubota KX91-3S2...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
2013 RAM 4500 (A50323)
2020 RAM Promaster City Mini Van (A53117)
2020 RAM Promaster...
2010 American LaFrance Thermoplastic Striping Truck (A52377)
2010 American...
PENDING SELLER CONFIRMATIONS (A54313)
PENDING SELLER...
