exhaust manifold leak question
   / exhaust manifold leak question #1
tomstewart
Richmond, TX
MF 231
I have a 1994 MF 231 2wd tractor. There is black oil leaking from the front port of the exhaust manifold.
Is this just a matter of changing the gaskets and/or exhaust manifold or both? Is there anything else I should be concerned with?
The tractor will give you one big puff of blue smoke when you crank it and a small blue puff if you pour the coal to it so to speak...meaning if you are at idle or low rpm and you give it a lot of throttle and significantly increase the rpm....otherwise does not smoke.
Thanks,
Tom
   / exhaust manifold leak question #2
Usually and hopefully it's just a matter of changing the gasket. I would start there. If it is still leaking, you could have a warped a manifold. For good measure, I would smear some that orange rev sealant on there. Can't remember what color sealant itnis
   / exhaust manifold leak question #3
Thanks,
Tom
Check to make sure none of the metal surface on the head exhaust has deteriorated. Another member here had a Z145 that had been leaking for so long it ate away some of the exhaust mounting surface on the head and had to build it back up with JB Weld. Then he could get a tight seal from the head to manifold.
It could be as simple as cleaning the surfaces up and installing a new head to exhaust manifold gasket. -kid
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52748)
2022 New Holland...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A52748)
John Deere 6105E...
2025 12V Diesel Pump and Hose with Meter (A50324)
2025 12V Diesel...
2017 Claas Jaguar 860 Forage Harvester (A52748)
2017 Claas Jaguar...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2015 FORD F-450 SERVICE TRUCK (A52472)
2015 FORD F-450...
