exhaust manifold leak on ym1401
   / exhaust manifold leak on ym1401 #1
MarkStewart
Pine Bush NY
Yanmar 1401
Hi. I'm having a problem with my yanmar 1401. There seems to be fuel leaking from the exhaust manifold. I checked the head gasket and it doesn't seem to be leaking. Also it doesn't seem to be using any oil and the anti-freeze level is the same as far as I can see. The anti-freeze also doesn't appear to be contaminated. When it runs it doesn't smoke excessivly, it puffs grey smoke when I hit the throttle or when it is under a load. Does this seem like a major problem? Will I need to rebuild engine? Thank you
See this link for pics. leaking exhaust manifold
2012 Crane Carrier Low Entry T/A Rear Loader Garbage Truck (A54814)
2012 Crane Carrier...
2007 Mahindra 4110 Tractor (A53117)
2007 Mahindra 4110...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2017 Ford Explorer AWD SUV (A51694)
2017 Ford Explorer...
2022 MACK GRANITE TANDEM AXLE DUMP TRUCK (A54607)
2022 MACK GRANITE...
Caterpillar 262 B 4 Tires Solid with Rims (A53117)
Caterpillar 262 B...
