Exhaust location...
   / Exhaust location... #1
JDGREEN4ME
Veteran Member
Southeast PA
John Deere 2520, John Deere X534, GT 225, GT 275
The exhaust on my 4110 is described as "under the hood". There is an option for a verticle exhaust stack, is there a reason or advantage to that design over the other? /forums/images/graemlins/confused.gif
   / Exhaust location... #2
To me, the stack would be a disadvantage. Looks like it would be up there to get caught on something or blowing exhaust in your face?
Either way the exhaust exits, the muffler would still be under the hood.
   / Exhaust location... #3
My last ride had a vertical exhaust and I thought there must be a better way. It made more noise, always caught branches, and collected rainwater then gave you a shower when you started the diesel. /forums/images/graemlins/frown.gif
My TC-40D is under the hood exhaust, and discharges low. It is very quiet, out of the way, and is a much better deal all the way around. /forums/images/graemlins/grin.gif
   / Exhaust location... #4
I second (or third?) the nod to under hood. Brutus has a vertical exhaust stack and it's always catching a branch. Just couple weeks ago, went into woods to pull a young lad & his girlfriend /forums/images/graemlins/blush.gif (truck) out of a mud puddle and knocked the exhaust stack over, bending one of the tabs that go over the turbo housing in the process. (later to be bent back when I fixed it)
It's in the way visually, WOULD catch water but for the flapper I put on it, and is (to me) more in the way.
Also, I have to remove it to take the hood off, whereas if it was under the hood it would not be in the way.
Richard
   / Exhaust location... #5
I much prefer the vertical exhaust. The 4300 always blew fumes in my face and it is less so with the 990. I also think it looks better. I don't go through the woods though.
   / Exhaust location... #6
heh heh heh guess there is never a "right" answer huh!
/forums/images/graemlins/cool.gif
   / Exhaust location... #7
I think the underhood is probably less likely to snag on things. It might add a little heat though.
I have no problem with my vertical stack but....then again I like diesel fumes /forums/images/graemlins/shocked.gif
Actually you only really smell it when you first start up and when you rev it momentarily and it's still only a light wiff
   / Exhaust location... #8
I have the vertical pipe coming out of the hood with a backward turn on the end of the pipe to prevent rain from entering the pipe. To me, this is a good design compromise, as it puts the exhaust high enough in the air so that I don't smell it./forums/images/graemlins/grin.gif But as has been previously stated, it does impair your forward vision a bit./forums/images/graemlins/frown.gif
My father owned several Massey Fergusons with the exhaust routed under the tractor and exiting behind the rear axle. This was great as long as you were the driver and did not have to work behind the tractor and as long as you turned off the engine every time you changed implements. /forums/images/graemlins/frown.gif
Most of the newer CUT's seem to have the exhaust exiting from the front of the engine, pointed to the ground at a slight angle and maybe I went for a test drive on the wrong day, but on the 4330 Kubota I test drove, I could not seem to get away from the smell of the exhaust no matter which way I turned in the dealers lot.
I personally like the cab tractors where the exhaust stack is attached to the right front post of the cab structure where it does not impair your vision and the exhaust exits up into the atmosphere. I guess there is no perfect setup or routing for the exhaust, you just have to use the type that best fits what you are going to use the tractor for or you are stuck with what it is equipped with from the factory if there is no other option available.
One thing that will be interesting to see in the future is how the new emissions standards are met by the manufacturers and how they affect that good old diesel smell that we all know and love. /forums/images/graemlins/cool.gif
   / Exhaust location... #9
I want some of that yummy, french fry smelling bio-diesel!
I never noticed any vision problem. It does hit stuff in the woods but that stuff would have hit my face next so maybe it's actually a benefit? /forums/images/graemlins/wink.gif
   / Exhaust location... #10
Not on my tractor the entire unit is vertical out of the hood.
2018 Bobcat T590 Compact Track Loader Skid Steer (A50322)
2018 Bobcat T590...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2007 Chevrolet C4500 4x4 Dump Truck, VIN # 1GBE4C3247F411826 (A51572)
2007 Chevrolet...
Ezflow 500 Gravity Box W/Cart (A50774)
Ezflow 500 Gravity...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2016 FREIGHTLINER...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
