Exciting morning on the hill. Oopps!
   / Exciting morning on the hill. Oopps! #1
CalG
Super Member
vermont
Hurlimann 435, Fordson E27n, Bolens HT-23, Kubota B7200, Kubota B2601
Sorry, no photos
But I was having some gravel delivered this moring to finish off the road repairs after the last wash out. (private drive serving 7 homes) Worst I'ld seen in 25 years, while nearby areas saw no damage.
Anyway
Had the stakes driven to mark the desired new grade. The Hurlimann fitted up with the Tiff-Line back blade. Ready to go!
The first load arrived and the driver laid it down so smoothly that no blade work was needed. This was going to be easy!
The truck returned with the second load , backing up the hill to avoid some overhead crossing wires when the dump body lifted. We are trying to build up the road where the years of run off have accentuated the crown to the point that it's dangerous when we get an ice storm. Sliding off the road and over a 15 foot bank is no fun at all, and we have had a few over the years, including the trash collection truck ;-)
I was standing about 12 feet from the back end of the dump.
Well, the dump body went up,
The driver started forward and down hill
The gravel started flowing out neat as you please.
When
All the sudden
Things went cock-eyed
The dump body swayed down hill to the right.
Things started looking really screwy!
Then the hole rig went over on the off side. Like a sailing ship losing it's rigging.
What a noise! All in slow motion!
I ran for the front of the cab which was mostly over the bank. Those few fast steps had me running through the "what if's" (I'm a trained Emergency Med ) (Fast motion?)
Rounding in front of the cab I see though the dust, fuel and fluids pouring from various locations. But the DRIVER is standing tall through the broken windshield. My calls of "You all right" get a positive as he calmbers up out of the open driver's window at top.
I run around to what is now the vertical undercarriage and offer a hand as the driver scrambles out. He is OK! Shaking like a leaf and PUMPED. Fight or flight kicking in in high gear!
We take a minute to collect... No one hurt, the truck is a write off. Half the load went over the bank, but the truck stayed on the road.
A look-see shows the hinge support on the downhill side collapsed with the load. Time and rust will do that. No fault to the driver.
He just the hapless victim of the ravaveges of time and business necessity.
1989 Ford ten wheeler.
The wreckers and recovery took about an hour to right the wrong and haul away the wreckage. Two big salvage rigs with cables from trees and criss-crossing everywhere.
What a trip!
Whew!
Maybe we can get a few more loads tomorrow....
Different truck I bet.
God I'm glad no one was hurt
   / Exciting morning on the hill. Oopps! #2
Never know what can go wrong...
Glad know one was hurt and the driver isn't on the hook for damages!
   / Exciting morning on the hill. Oopps! #3
Good to hear nobody was hurt. Shame about he truck.
   / Exciting morning on the hill. Oopps! #4
Sounds like a bad place for the hinge to break. Guess you can't pick 'em.
   / Exciting morning on the hill. Oopps! #5
Glad no one was hurt except maybe some dirty underware. You never know what will happen.
   / Exciting morning on the hill. Oopps! #6
Accidents can happen in a split second. I'm sincerely glad that the Driver wasn't hurt.
   / Exciting morning on the hill. Oopps! #7
Now that everybody is OK and the truck is gone, are you able to recover the load that was spilled off the road or is it just to steep? Sounds like there's still potential for accidents if you start working on that hill with the tractor.
   / Exciting morning on the hill. Oopps! #8
Has the company identified a plan to clean up the fuel and fluids that spilled? If it mostly landed on the road they may be able to scoop that out and just lay down some new stuff. Depending on how much spilled and what is downhill from the spill site (stream or well or what have you) you may want to ensure that doesn't get a chance to sink into the ground too far.
   / Exciting morning on the hill. Oopps! #9
Agreed!
I watched few hundred gallons of fuel run down ditch and into a stream and pond below... :( Big cross country semi t-boned a Cadillac, jack knifed and took out a phone/stop light pole. The pole broke but took bottoms out of both tanks prolly 300+ gallons... Fire trucks put in booms to try & isolate spillway of dam of the pond and then clean up crews half drained pond and cleaned out ditches. Cadillac was on it's side older lady ran stop light in front of driver... not his fault but sure his insurance ended up paying a ton, we were in a 20' box truck right behind the Semi, we waited for the semi to go by and caught up to him on the up hill run to the accident spot. Had we not let him go on by it might have been US hitting woman...
Mark
Suprisingly, very little of the several fluids were spilled.
Fuel, non at all! That was a big concern. But the tanks were nearly empty. and the contents stayed in. Until the salvage crew drilled and pumped them dry before the flip back to upright.
There was some hydraulic fluid out on the hard roadway, Maybe 3 gallons or so. The rear diff leaked out a few quarts tops. The engine oil left a black puddle about 2 feet around.
The clean up was shoveled and tossed into the empty dump bed before the rig was towed off . The salvage crew must have or take the resonsibility. (I'm sure it's a billable item) Looked good when we dressed it out last night. The truck impact sure left a cleft in the side of the road though!
The entire job is done now. 100 yards of gravel spred and raked fine. It looks very good. The years had taken a toll, and there wasn't much but bones to work with when trying to cut out the washboard or work things back into shape after a big rain. Now there is something. I hope we don't get another frog choker that washes everything over the edge.
The spilled gravel is about 3 feet down the bank, But it's another ten feet if things get out of control. I looked at it trying to see a way to safely drag it up. To risky for 6 yards of dirt!
Of course now that the job is done, It is obvious I need a bigger York rake to go along with the blade! When does it stop? ;-))))
UNUSED PALADIN SKID STEER HYDRAULIC BREAKING HAMMER (A51243)
UNUSED PALADIN...
UNUSED LANDHONOR BS-12-2500G BALE SPEAR (A54757)
UNUSED LANDHONOR...
2013 Dodge Charger Sedan (A52377)
2013 Dodge Charger...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
Towable Diesel Fuel Tank with Pump (A53421)
Towable Diesel...
Adams 6T Fertilizer Spreader (A55301)
Adams 6T...
