etpm
Veteran Member
- Joined
- Jun 30, 2021
- Messages
- 2,077
- Location
- Whidbey Island, WA
- Tractor
- Yanmar YM2310, Honda H5013, Case 580 CK, Ford 9N
Several nights ago I was slicing potatoes 1/8" thick on a mandolin slicer. Because of my inattention I managed to slice a 1/8" thick section from my little finger. It was pretty bad, I saw the fat bubbling out through the blood. I managed to remove not only the epidermis but also the dermis. I decided the next morning, after looking at the wound again, that a pro needed to look at the wound. So I went to the walk in clinic that is fortunately only a few miles from where I live. They cleaned the wound which was about 3/8" by 5/8", too big to just pull the wound closed with stitches. That cleaning process was by itself enough to very strongly suggest that I should not wound myself in a similar manner ever again. But the exceptional part is truly exceptional. The doc opened a package that had a small piece of some sort of foamed material. She cut it to size and pressed it onto the wound. Lotsa fun. But it stuck and stopped the bleeding, which was still fairly profuse. I was told to leave this foam type stuff on the wound until it falls off by itself. And not not only did the wound stop bleeding but the pain from all those exposed nerve endings is gone.I don't know what the foam is made of but it is truly remarkable. I suspect our military uses it a lot. It's been 5 days now and my finger doesn't hurt. I don't know what was put on the wound but it is certainly an exceptional wound care product and I am very glad that some scientists figured this stuff out. I was told that because of the large amount of flesh removed that I should expect 3 to 4 weeks for the finger to heal to the point that the foam stuff falls off and that new skin will at least cover the wound. I was also told that there will probably not be a fingerprint any more from the wounded area. Still, I want to say again how happy I am that medical science figured out this stuff. Fingers are very sensitive and I know if I just bandaged up my finger it would be super sensitive for months while it healed. YAY Science!
Eric
Eric
