EXCELL XR2600 Pressure washer replacment pump options/Help. Thanks
   / EXCELL XR2600 Pressure washer replacment pump options/Help. Thanks #1
JOE G
Eastern NY
Husqvarna / John Deere
Hi, I have a EXCELL XR 2600 with a Honda motor Pressure washer that has been sitting for many years. I t fired up without issue after two pulls, I went to use it and the Hose blew, New hose then the pulse Hose blew Replaced that now the pump went lol. I would like to replace the pump and I see that there are many options out there and I am not sure which option to choose, I would like a fairly straight forward swap. Any help on which to choose and where to get one would be appreciated. Thank you
   / EXCELL XR2600 Pressure washer replacment pump options/Help. Thanks #2
I am in the same boat. Looking for a new pump for my Simpson pressure washer. Not much help to you but good luck in your search. JC
I ordered one from a company in FL, It has good reviews so we'll see.
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 YOUERT YOU12 1-Ton Mini-Excavator with dozer blade (New/Unused) (A59225)
2025 YOUERT YOU12...
pressure washer, and trailer (A56859)
pressure washer...
2007 FREIGHTLINER COLUMBIA 120 (A58214)
2007 FREIGHTLINER...
(15) UNUSED SDLANCH 94" X 42" HEAVY DUTY FLOOR (A58376)
(15) UNUSED...
