Excavator Blade: Behind or in Front?
   / Excavator Blade: Behind or in Front? #1
Suburban Plowboy
Platinum Member
FL
Kubota L3710
1. Experts on the Internet say to keep a mini-excavator's blade behind you when digging.
2. Experts on the Internet say to keep a mini-excavator's blade in front of you when digging.
Help.
One of those sources says to park with the cab at 45 degrees to the tracks to provide a step to dismount on. The other says this is a critical safety error.
   / Excavator Blade: Behind or in Front? #4
I suppose in theory if you leave it running you could run yourself over using the track as a step. Most have a safety interlock or if you just shut it down it should be safe. I’ve only run one a couple of times and ended up going at an angle and using the track as a step. I’ve always seen the blade out front.
   / Excavator Blade: Behind or in Front? #5
Well, both are correct in certain circumstances.
Super-light machines are very different than minis that way tons: you can easily drag a 1-ton-ish excavator around with the dipper, so anchoring with the blade is more important than ever. Sometimes in front is best, which also keeps rocks off your sensitive bits (wheel motors).
Starting a hole is tough when you can push down with much more force than the weight of the machine. Blade-behind maximizes the downward pressure of your teeth on the ground.
But blade-front allows you to lift more without tipping.
Slopey ground (all I have) means blade positioning is everything.
   / Excavator Blade: Behind or in Front? #6
I always try to use the track as a step. Ever slipped off that muddy metal step? It hurts.
Digging over the blade for stumps, you have more power. Ditching either way works, but with the angle blade you have little room.
I'm trying to get up to speed with my cheapo Chinese gas job. So much bad information out there.
For example, people complain that the seat gets hot, so some are saying to insulate the underside of the sheet metal under the seat. But that cooks the engine, which people say is already too hot.
My plan is to remove the door, since it seems to serve no purpose anyway.
   / Excavator Blade: Behind or in Front? #8
I found when digging to use the boom in and try to avoid over downward pressure. Scrap towards you while curling the bucket and you will avoid lifting your unit off the ground as much.
   / Excavator Blade: Behind or in Front? #9
I keep the blade behind me for general ditch digging. The blade cost a couple ft of ditch before I have to move again. If I’m doing something hard like pulling a stump or digging down a hill I’ll put the blade foward for stability. And parking it 45 degrees over the track is my preferred method for getting out of the machine.
  • Good Post
Reactions: M59
This machine really sinks in my sandy yard. If I move it to a location with the blade in front of me, and then I spin it to put the blade behind me, it makes it more likely I will get stuck when I try to leave.
2015 PETERBILT 389 MID-ROOF SLEEPER (A48992)
2015 PETERBILT 389...
2025 Kivel 48in Forks and Frame Tractor Loader Attachment (A46683)
2025 Kivel 48in...
Linde H25T 5,000lbs Propane Forklift (A49346)
Linde H25T...
2007 Isuzu FTR Truck, VIN # 4GTJ7F1357F700209 (A48836)
2007 Isuzu FTR...
16FT BOLSTER (A48992)
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
