EX3200 Headlight bulb
   / EX3200 Headlight bulb #1
Burns331
Bronze Member
Does anyone know what the model number for the headlight bulb is? I would like to put some LED ones in. Obviously going to mount some LED lights else ware to. Tried searching with no luck.
Thanks in advance.
   / EX3200 Headlight bulb #2
Don't know if you have a FEL ;if you do it blocks most the light any-way.High mounted LED's will give you a lot more light.Also put one or two facing back.
I do have a FEL. Bulbs are cheap. Hence im going to put them in and add more lights.
   / EX3200 Headlight bulb #4
I have a Cub/Yanmar Sc2450, so I do not know if the headlight bulbs are the same but here are the bulbs I got for it:
I replaced all of the incandescent bulbs on my Sc2450 tractor with LED bulbs.
What a difference the led's make, here is what and where I bought. It took a lot of research to find the best bulb for the money.
Tail Lights Bulb # 1157
https://www.amazon.com/dp/B00MC6WP3A/ref=dp_prsubs_1
Hazard Lights Bulb # 1142
https://www.amazon.com/iBrightstar-Newest-Projector-replacement-Reverse/dp/B0739VPVWT/ref=sr_1_4?s=automotive&ie=UTF8&qid=1547571035&sr=1-4&keywords=1142+led+bulb
Side Front Bulbs # 1156
https://www.amazon.com/JDM-ASTAR-Lumens-Chipsets-Projector/dp/B00VUP3Y34?ie=UTF8&psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00&tag=viglink20660-20
Headlights # H6m
https://www.amazon.com/Ruiandsion-Replacement-Motorcycle-Headlight-Daytime/dp/B07MP2RCJK/ref=sr_1_fkmr0_1?ie=UTF8&qid=1547570471&sr=8-1-fkmr0&keywords=100W+White+H6m+70023+LED
only thing i can find that will work is from china. its a P30d base, and only china has them in LED. Oh well here goes nothing
i bought a set of LED's from china. Work great. But i noticed that on the old filiment bulb and the new LED they are 2 stage, hi/low i assume. and there are 3 wires to the bulb, but no selector switch, just an on off switch. Seems pretty odd to not use both sides of the bulb.
   / EX3200 Headlight bulb #7
Yes my Sc2450 incandesent bulbs used both fililments and has 2 contacts and the leds base has 2 contacts also.
odd only one side of mine light up. Looked at the diagram and it looks like its only made to run on 1 side. I may just solder between the two contacts on the bulb and try it. should put power to both sides and then use the body for ground still.
2022 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
CAT FORKS W/ QUICK COUPLER (A50854)
CAT FORKS W/ QUICK...
SCAN FOR HAULING AND FINANCING INFORMATION (A51242)
SCAN FOR HAULING...
2020 VOLVO VNL760 SLEEPER (A51222)
2020 VOLVO VNL760...
(INOP) CATERPILLAR TL943 TELESCOPIC FORKLIFT (A50459)
(INOP) CATERPILLAR...
