ex2900/3200 hood vibration just started
   / ex2900/3200 hood vibration just started #1
alltherage
Western NY
2011 Cub Yanmar EX2900. 1939 Farmall A, 1940 Farmall H, 1959 Oliver 770
it's just at certain rpm's, and nothing major, but it's a new sound and I don't want it!
anyone know of a quick and easy way to quiet it. i literally touch it with a finger and it stops...very slight but ya know....
   / ex2900/3200 hood vibration just started #2
I have the perfect fix for you. Find a nice size rock and duct tape it to the hood. Most duct tape is rated for 200 mph so you should be good:laughing:
Ok i take it you have checked to make sure things are tight. Also check to make sure the hood latch holds nice and tight. If all else fails you can put alittle weight under the hood i think its fiberglass/plastic so a magnetic weight is out of the question. Good luck.
   / ex2900/3200 hood vibration just started #3
If it's vibrating against something, like the dash cowl, etc, you can take a length of tubing, like vacuum hose, slice down the length of it and then fit it around the edges of the hood so it snug fits and doesn't cause the vibration. Sort of like a weather strip on a car door. Worked really well on my garden tractor hood which vibrated from day one.
   / ex2900/3200 hood vibration just started #4
I would think there would be a reason for this which could be an underlying problem. I realize that some areas are very cold this time of year, I used to live in Grand Forks, ND, so maybe it's idling a little harder than normal. I know when mine started vibrating hard and making a noise, the air cleaner bracket was broken. Once I replaced that, the noise and vibration went away.
2013 PETERBILT 367 DAYCAB (INOPERABLE) (A52472)
2013 PETERBILT 367...
EZGO (A50324)
EZGO (A50324)
2016 Kawasaki 70 TM 7 Articulating Wheel loader (A52748)
2016 Kawasaki 70...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
1996 HEIL TRAILER INTERNATIONAL FUEL TRANSPORT TRAILER (A52472)
1996 HEIL TRAILER...
2004 PETERBILT 379 9 CAR HAULER (A52577)
2004 PETERBILT 379...
