Evolution Steel Saw..
   / Evolution Steel Saw.. #2
that blade will never last,i use a carbide slitting saw on a milling machine i flod it with oil and still blade dosent last to long.
They are claiming 1000 cuts of 2x2 1/4 walled tubing..
Which seems reasonable, just curious if you cut 1" thick piece it it heats up more and ruins the blade..
   / Evolution Steel Saw.. #4
My neighbor and I was talking about this saw a while back when first seeing it advertised on TV, He was supposed to had got one, I need to check back with him and see if he ever did? He is a welder by trade and uses a power hand held Band saw and was a bit skeptical of this new style circular saw and could not figure out how 2 blades running opposite of each other cut take a bite into something, I Have used a circular saw for over 30 years and when a blade gets dull from just cutting wood ya might as well throw it away and go for another, let along cutting through steel ;) I find it hard to believe to be able to cut like the ad shows, to cut through metal the blade needs to have as fine of teeth can get, although Lately I was surprised while installing some Ipe decking wood, that I was told to use a 16 tooth carbide blade for best cutting, and sure enough it cut very smoothly with minimal splintering:) Old dogs can learn new tricks:D
Yeah, was interested in the chop saw version. Video looks like it goes right through it...
   / Evolution Steel Saw.. #6
My brother uses one at work cutting aluminum.
They ate up several blade before they figured out they need to use some sort of lubricating wax on the blades.
I think they are happy with it now.
   / Evolution Steel Saw.. #7
Blades wont last long.Own skill saw typ.Cost to much for blade replacement.
   / Evolution Steel Saw.. #8
Haven't used the Evolution but use the 14 inch Milwaukee extensively. They cut great! Best on steel thicker than 1/4". One of the videos shows a guy with short sleeves and safety glasses. NEVER use without a good welder's jacket and full face shield with safety glasses underneath! The chips are sharp, hot and supersonic! The chips are fairly easy to clean up with magnets but they'll cover your entire shop with just one cut. Plan on about 15 minutes clean up. They'll stick into your shoe soles so make sure you take a half-hour to dig 'em out or take off the shoes before you go home and hit the Boss' hardwood floors.
The blades are expensive and the blade teeth are very sensitive to impact. Just cutting through a piece of grating or expanded metal can break a tooth as the blade breaks through and jumps to the next wire. Once a tooth is broken, the rest go like dominoes. We probably ruined $700 worth of blades before we learned how to gently start every cut. We still screw up occasionally. One slip and $100- $175 gone! If you're really careful, they'll make quite a few cuts but we've never gotten near 1,000 cuts out of any brand blade. We've had some success brazing on a replacement tooth taken from another blade. That takes so long we only do that on a near new blade.
In summary, they likely cut smoother and faster than anything you've ever used. The saws are expensive to buy and the blade cost is high. Clean up is a bit of a hassle and shouldn't be put off as the chips embed themselves in shoes and clothes and will end up all over your car and your house. We arrange everything we want to cut with this saw so we can cut it all in "one sitting" then clean up and move on.
   / Evolution Steel Saw.. #9
I just bought the Rage circular saw but don't have enough cuts yet to get a good idea on longevity. It does cut good however and the steel doesn't get hot. Like stated before though,watch out for the chips.
   / Evolution Steel Saw.. #10
My Deere dealer had one, but it is not there anymore. The noise was deafening, and some say it just didn't work well.
One of the video's shows a guy with no ear protection, and no eye protection. Maybe that was intentional to show off the saw.
Can't say if they will catch on. Time will tell.
2022 Ford Maverick Crew Cab AWD Pickup Truck (A50323)
2022 Ford Maverick...
Kubota Salt-Spreader (A52384)
Kubota...
2014 Ram 5500 4x4 Altec 37G 37ft Bucket Truck (A51692)
2014 Ram 5500 4x4...
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2002 Ford F-350 Flatbed Truck (A51691)
2002 Ford F-350...
2017 E-Z Beever M12R Towable Brush Chipper (A51691)
2017 E-Z Beever...
