Everything Needed for 50 hr Service?
   / Everything Needed for 50 hr Service? #1
Hdoilcan
USA
2018 KIOTI CK3510SE CAB, 2475L BACKHOE, 72 BOX BLADE, 72 REAR BLADE, 72 LANDSCAPE RAKE, 1,250 LB 55 GAL DRUM BALLAST, 2018 FERRIS IS 700Z, 26HP 810 VANGUARD ENGINE
My dealer is including everything needed for me to do the 50 hr service in the price I'm paying for my new L3540. What should I expect to receive for this such as filters and fluids ect?
   / Everything Needed for 50 hr Service? #2
'Per the manual', Engine oil filter, engine oil, HST oil filter, hydraulic oil filter. You will want some SUDT2 to top off hydraulic system after filter change. Plus, check your front axle, they all seem to be a little low after use. Philip.
   / Everything Needed for 50 hr Service? #3
The 50 hour is really pretty easy, it's covered in your manual and here is something I found handy on the first couple of times I serviced ours.
Kubota L-40 Series Service
   / Everything Needed for 50 hr Service? #4
My dealer gave me all the filters and fluid for the 50 hr service as well. It's a great way to learn a little more about your gear as well as save some bucks by DIY.
Thanks guys for the info.
   / Everything Needed for 50 hr Service? #6
if your dealer gives you everything for your 50hr service.your looking at $700 more or less.
   / Everything Needed for 50 hr Service? #7
No. Per the manual, for the GrandL series, only the filters I listed above are required for 50 hour service. No fluids except engine oil are required. If you want to do more, that is up to you.
$700 sounds high. At my 50 hour service, I elected to change ALL filters (including air and fuel filters) and replace ALL fluids. That cost me $162 for Kubota filters, $285 for SUDT, and $50 for 5w-40 enigne oil. That came up to $497.
Philip
   / Everything Needed for 50 hr Service? #8
your filters an air filers must be cheaper at your dealer.because on my old mx5100hst all of that cost me close to $700.if i got everything.
   / Everything Needed for 50 hr Service? #9
Just did my 50 hour service on my L4400( 4 years old with 47 hours) I purchased the hydraulic filter at Kubota, but got the oil filter from Donaldson and the oil from Caterpillar.
We'll this is what the dealer gave me today...... I will show the the prices that are listed on the invoice even tho it was included in the cost of the tractor.
Engine Oil Filter $15.34
Hydraulic Fluid Filter $54.32
Hydrostatic Oil Filter $75.44
Fuel Filter $5.31
2 gallons 10w-30 Engine Oil $25.49 each
2 Gallons Super UDT2 Trans/Hydro Fluid $28.49 each
Total $258.37
2004 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A55745)
2004 INTERNATIONAL...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2023 54' Hooklift Dumpster 15 Cubic Yard (A55788)
2023 54' Hooklift...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
2014 Ford Taurus AWD Sedan (A55853)
2014 Ford Taurus...
