Rake Everything Attachments Pine Needle Rake
   / Everything Attachments Pine Needle Rake #1
Stowe Boy
Greater St. Louis area
several
Has anyone used the Everything Attachments Pine Needle Rake as a dethatcher for their lawn? If so, what are your thoughts? Thanks.
   / Everything Attachments Pine Needle Rake #2
I've used their Pine Needle Rake for collection of Pine needles and cleaning up downed, limbed tree debris ...mostly Pines. It works well for that. But never have I tried using it for dethatching a lawn. Seems to me that it would not work all that well.
   / Everything Attachments Pine Needle Rake #3
   / Everything Attachments Pine Needle Rake #4
Now that you mention it, I may try using my PNR to dethatch parts of my lawn. It may not be the best tool, but might be good enough. Sounds like it's worth a try for Fall rejuvenation/reseeding. And I already have a Cyclone Rage to pick up the thatch.
   / Everything Attachments Pine Needle Rake #5
After 7 years of use I have worn out my first pine needle rake (Lienbach) and need to replace it. I will be buying the EA rake with replaceable tines next week.
These pine needle rakes are very useful for their intended use as well as smoothing and covering seeds. One of the more useful implements I have and has stood up well with lots of use over the years. I feel it is a good cheap finishing tool with a lot of uses.
   / Everything Attachments Pine Needle Rake #6
Thanks, jenkinsph.......
It's comforting to know that some of my newbie purchases proved useful to me. Maybe Stowe Boy can decide as well.
Thanks Jeff9366. I must have done something wrong in my search.
Thanks jenkinsph.
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
Wright Stander X (A44502)
Wright Stander X...
2005 STERLING L7500 SERIES TANDEM AXLE CRANE TRUCK (A43004)
2005 STERLING...
John Deere 6135E (A44501)
John Deere 6135E...
Kubota KX057-5 Compact Excavator (A44789)
Kubota KX057-5...
2016 Nissan Sentra Sedan (A44572)
2016 Nissan Sentra...
