Ever hear of EZT or H&H toothbars?
   / Ever hear of EZT or H&H toothbars? #1
GSS
Pgh, PA
Cub Cadet 7360SS, MF1100 & JDx585
I had all planned on getting an FCC from a local equipment shop, when I called them and they said they could order one, but they have EZT's (made by H&H Manufacturing) in stock. So, does anyone know of them or possibly own a toothbar or something else made by them?
The 64 incher seems comparable in price to the FCC at $352 (7-8 teeth).
Also, what kind of tolerances have you seen on your toothbars? My bucket inside width is 64.5" and they said the 64" will work.
Thanks.
- Gerald
   / Ever hear of EZT or H&H toothbars? #2
Hi Gerald,
Somehow the reply I tried to submit was lost...so here goes an abbreviated form.
I have an H & H toothbar.
It is well made and I love it. I would buy it again in a heartbeat.
This company is located in Green Bay WI
It is the attachment that I appreciate most.
Use a good holesaw to cut the 1" holes for the mounting bolts.
A little narrower than the bucket inside is OK. Mine was and that may make taking it back off a little easier after using it.
Go for the H&H. Your won't be sorry if the one you are looking at is built like mine is.
Hope this helps...Bill
Hey Bill,
Thanks for the feedback. I got a call back from Groff Equipment and also spoke to 3 Rivers Equipment. They both handle the FFC's, but Groff's the one with the H&H. They explained that the H&H's are designed mainly for buckets with replaceable cutting edges but can be used with welded ones, like ours. But are more expensive b/c of this, ie $353. I decided to go with the FFC. It was $280 plus shipping. They'll also drop ship it to my house direct from the factory. Save me some running around...
I can see the multifloral shaking in its roots already!
- Gerald
MAJOR LOT NUMBER 260 (A53084)
MAJOR LOT NUMBER...
2025 CFG Industrial MX12R (A50123)
2025 CFG...
2017 Hammerhead Off-Road Utility Cart (A51691)
2017 Hammerhead...
2010 KMC 3376 Peanut Combine (A53473)
2010 KMC 3376...
INMY Manual Landing Gear (A51692)
INMY Manual...
