escavader
Veteran Member
Igot a alignment problem on my big tex,rear drivers side tires keep wearing out on the inside .All 3 others wear perfect .you can actually sight down it and see its off.
Ive had lots of suggestions,from chaining and jacking ...to replacing...Best idea,im considering was to cut almost al the way around tube with sawzall ,bend it in place then reweld[not sure which rod i should use,or how thick that tube is],id have to remove wire in tube first[goes to brakes]
I took off the drum ,backing plate etc,cant get to where the spindle is welded in tube because the plate the brake assembly bolts too is also welded right in front of...
I really dont want to bend the axle more,because the other opposite tire wears perfect
Idont know how it happened either ,never overloaded or beat on the trailer.axle and brakes still looks new ,not a spot of rust,id really rather fix then replace.
any backyard mechanics got a fix for me?
ALAN
ALAN
