Cord
Veteran Member
I have a Deutz 1011 in a skid steer. With the cold temps this year, the thing has been a bear to get started. This appears to be inherent to the engine because I used another machine with the same engine and noticed it too was having trouble starting. It would appear the drag of the cold pumps doesn't allow the starter to spin the engine fast enough. When it was zero I couldn't get the engine to spin fast enough to make smoke. A new battery and jump start didn't help. This engine is oil cooled so adding a heater is difficult. I added silicone oil heater and also put one on the main oil tank. In 20 degree temps and two hours on the heaters she now spun fast enough to make smoke, but no attempt to fire. That oil heater just isn't putting enough heat into the engine. Took the air filter apart and sprayed some ether on the inner filter. Without using the preheater I cranked the engine and after a second it fired and idled nicely.
Trying to do more research on how to get this thing to reliably start. This engine has a single manifold heater. Wish it had glow plugs because they are much more effective. There is a second plug where I could add another manifold heater. Not sure if I need a second relay or not. Dealer isn't sure either. I've read a couple of on-line owners manuals and the 1011 is available with a ether start system. I'm considering the Kat's 33100 because it will be easier to install than the cable system. Anybody know where this system is piped in? Do I drill the manifold after the turbo so the ether goes to all cylinders? Do I pop the plug out and then use that port? Will the heater cause the ether light in the manifold? If they inject the ether after the heater, then is it a 4 port system?
