espresso: pump vs steam
   / espresso: pump vs steam #1
RobertN
Super Member
Shingle Springs California
New Holland TC40D
We have two machines. One is an older Krups steam machine. The other is a Starbucks brand pump machine. It's funny, as my wife likes the simplicity of the steam machine, while I like the function of the pump machine.
I've mostly been using the pump machine for a long time now. Yesterday, I made some in the steam machine. Even though I like LOTS of chocolate in my mocha, I could tell a very distinct difference in espresso, even though we used the same coffee beans.
I had never thought about it before. There does seem to be a big difference in the extraction using steam compared to pumping the hot water through the ground coffee.
I like the flavor I get out of the pump better. It seems richer and creamier.
   / espresso: pump vs steam #2
<font color=blue>There does seem to be a big difference in the extraction </font color=blue>
That's it in a nutshell. The goal in making great espresso is to provide just enough pressure to make sure the hot water passes thru all the grounds. Pumps are very good at keeping the pressure consistent and low, but the steam units try to ram it thru quickly. If the grounds are not properly tamped down a pump will be forgiving whereas a steam unit will find the path of least resistance, which often leaves dry spots in your grounds basket.
Pete
   / espresso: pump vs steam #3
I have a Briel pump machine and it works fine. use star bucks coffee ground for a pump machine.
   / espresso: pump vs steam #4
I just gotta ask, Why don't ya just boil it in a percolator for about 20 minutes with some chicory added in and have a full cup of coffy instead of them little tiny cups of whatever ya call it?
   / espresso: pump vs steam #5
<font color=blue>use star bucks coffee ground for a pump machine</font color=blue>
Any darker roast will do fine, regardless of brand. The one caveat is you want to use fresh coffee for espresso. There is more oil in dark roasts, and oils quickly go rancid. Finding fresh stuff is pretty easy. First, make sure the package has a pressure-relief valve on it; without a valve the coffee must be staled before packaging or the bag will rupture from gasses given off by the fresh beans. Secondly, a puffy bag is always your best bet; this means it was packaged so fresh the coffee was still degassing. If the bag is limp or (worse) hard as a brick, it was allowed to go absolutely stale before going into the package. And if you see "vacuum packed" coffee, run the other way. It has to be practically rotten before it can be vacuum packed
Pete
Green Mountain Coffee in Waterbury, VT
   / espresso: pump vs steam #6
I have them grind it fresh at the star bucks down the road. not store bought already packaged.
To answer your question, because that's what my grandparents used to do/w3tcompact/icons/shocked.gif My Grandma made "Cow Poke" coffee, in one of those big commercial 20 cup pots. She used Folgers, and added it by the pound. A spoon would stand up in the cup until it dissolved... My Grandpa would drink it all night long while talking on the Ham radio's.
I like my espresso much better/w3tcompact/icons/grin.gif.
   / espresso: pump vs steam #8
Steven -- Just don't fall for that bulk bin trap. Here's how that happens. The coffee is packaged fresh from the roaster in nitrogen-flushed five pound bags. The coffee is sent to the retail outlets in those bags, perfectly protected from exposure to evil oxygen. The store staff rip open the bags and dump the coffee into open bins where it is exposed to air and begins to oxidize immediately. Customers see the beans and think "fresh" when what they are getting is all too often old and stale. Buy only what you can use in one week, and make sure it's sealed, nitro flushed, and vented. In most cases the 10-12 oz packages are by far your best coffee.
Pete
   / espresso: pump vs steam #9
Thanks I'll rember that the next time I get more ground.
   / espresso: pump vs steam #10
Steven -- If you like espresso that much you might think of getting a grinder. The finer the grind the faster it goes stale (greater surface area exposed to air), and espresso grind is about as fine as it gets. You can pick up a cheapy for about $15 and it really does make a difference. Coffee's what I do for a living; sure like to see each cup or shot be all it can be. /w3tcompact/icons/grin.gif
Pete
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2023 CATERPILLAR 299D3 XE SKID STEER (A51246)
2023 CATERPILLAR...
Vibratory roller attachment (A53421)
Vibratory roller...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
EZ-GO MPT 1000 Electric Utility Cart (A51691)
EZ-GO MPT 1000...
CUSHMAN HAULER 1200 GAS GOLF CART (A51406)
CUSHMAN HAULER...
