Error Code 02 John Deere 4720
   / Error Code 02 John Deere 4720 #1
APB4289
Canton, MS
John Deere / 4720
John Deere 4720
Error Code 02
Engine runs fine, tractor won't move in any gear.
Transmission fluid is fine.
Have unconnected Batterynto try and get an electrical reset.
Brake is not on.
What else can I do?
   / Error Code 02 John Deere 4720 #2
Error 2 means that the forward pedal sensor is out of range. Could be a loose wire, out of adjustment, or just a bad sensor. Check under the right floorboard and see if there is any disconnected or damaged wires. A stick or something could have caught some wires and pulled them loose. Did tractor quit while running or did code come up when you first started it?
It just came up when I went to use it this morning. It was running fine, yesterday.
I can't find any loose wires.
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
2000 SPARTAN SUMMIT RV (A50854)
2000 SPARTAN...
1263 (A50490)
1263 (A50490)
PORTER CABLE 150 PSI AIR COMPRESSOR (A50854)
PORTER CABLE 150...
2015 KENWORTH T800 MID-ROOF SLEEPER (INOPERABLE) (A50854)
2015 KENWORTH T800...
2005 LUFKIN 48X102 SPREAD AXLE FLATBED (A50854)
2005 LUFKIN 48X102...
