Floater
Starting a couple of weeks ago, the temperature gauge has both slowly, and rapidly, increased to hot and "needle pegged" with no apparent over-heated engine. Gauge shows warm up as normal, runs normal for awhile, then suddenly shoots upwards. I have flushed and refilled cooling system, installed new thermostat, replaced temperature sensor/sender unit. No change! The gauge, when temp sensor wire is grounded, goes to full hot. Also, the gauge sometimes does not go all the way to off-peg when ignition shuts off....it may stop 3/16" off the peg....but not always. I have not pulled the water pump, as it seems not to be a circulation issue. Any thoughts?
