Equipment Trailer plans
   / Equipment Trailer plans #1
TuckR
Spokane, WA
Kubota L3302
Hi All,
Googling "Free trailer plans" yields a ton of junk. Does anyone know a good resource for trailer blueprints? This would be for a 16' 7k car hauler style trailer for moving my tractor around.
   / Equipment Trailer plans #2
Hi All,
You might want to price everything out -steel, deck material, running gear etc. before you dive in. If your goal is making a cheaper trailer than you can buy, you may be surprised that you're not saving much if anything and you're investing many hours of labor.
If your goal is making something different than you can buy or you got a screaming deal on the correctly sized steel/running gear/etc. or you just want the satisfaction of making your own, then I certainly don't want to discourage you.
For plans I would suggest that you visit a local reputable trailer place that sells to professionals like PJ or BigTex etc. (NOT Home Depot, Tractor Supply, etc.) with some calipers, a notepad, and a cellphone camera. The better manufacturers do structural engineering analyses on their designs and you can't go wrong by duplicating them. Also pay attention to where the axles are located relative to the tongue and the bed length as that makes a big difference in terms of loading and stability going down the road.
It's easy to use too heavy materials/overbuild a trailer and have the unloaded weight suck up more load capacity than necessary. Again this goes back to the reputable manufacturer's engineering analyses determining optimal weight/strength/spacing/overlap/etc.
Good luck to you whatever you decide
   / Equipment Trailer plans #3
Building a one of trailer is a loosing proposition. Just buy one.
   / Equipment Trailer plans #4
Figure out all the prices yet?
I bought just want you want to build but with a wood deck new for $5300 out the door less than 1yr ago. Appalachian trailer in PA and OH.
   / Equipment Trailer plans #5
I'd double check your DMV rules on homemade trailers too. In MA it used to be pretty easy, as you the builder, registered for whatever weight you wanted within reason of the axle(s) and tires (in which you needed proof of buying). They have made it significantly harder from what I recall.
   / Equipment Trailer plans #6
I wouldn't build one. I have a stack of 6x6 x 3/8" angle. Axles everywhere. Hitches, springs, u bolts. Welder and torch. Not interested in building a trailer. Too many can be bought around here. I may extend mine to 20' 3" one day. I hauled a Dodge super cab Cummins and it barely fit. Plus too heavy on front.
Good info here, thanks all. I have two 3500lb axels gifted to me and electronic breaks. I also have a new-to-me tombstone welder just begging for a project. It does look like buying might be the better option for me after all. I’ll store these axles for now.
Thanks again
   / Equipment Trailer plans #8
Thanks again
Why not sell those axles?? I was looking at a car hauler sized trailer this past summer that had a bend axle and need some frame work but decided it wasn't cost or time effective for me to mess with. I think I could have snatched up some used axles at work but I was still nervous about it. I might even have got the trailer for free. I do see used car hauler sized trailers on FB marketplace for sale all the time.
   / Equipment Trailer plans #9
Buy a project trailer with good “ bones” and swap in your parts
   / Equipment Trailer plans #10
I've seen a number of wrecked travel trailers that have decent frame/axles/tongue for cheap because they don't have a deck. Buying one of these, reinforcing the frame and fabbing a deck might also be a cost effective way to get what you need. Going this route also bypasses any homemade trailer red tape if you happen to live in one of the nanny states
2005 Toyota Highlander SUV (A42744)
2005 Toyota...
2006 GMC 8500 Forestry Grapple Truck (A44571)
2006 GMC 8500...
2007 PETERBILT 378 FLAT TOP (A45046)
2007 PETERBILT 378...
2006 Ford F-350 XLT 4x4 Crew Cab Pickup Truck (A42744)
2006 Ford F-350...
2015 Ford F-250 Ext. Cab Pickup Truck (A42744)
2015 Ford F-250...
1997 Ford LT9000 T/A Day Cab Truck Tractor (A44571)
1997 Ford LT9000...
