Equipment Dolly
   / Equipment Dolly #1
HRS
Georgia
What a difference wheels make! I've been manhandling my rotary cutter around my shop for some time. I knew that if I kept this up, I'd eventually hurt myself, so the other day I got the bright idea to buy a furniture dolly for the front of it while visiting TSC. This made a huge difference. I was able to slide her out of the way against the wall with relative ease. So this got me to thinking. What if I got serious and built a dolly for each piece of equipment. My first attempt was to create one for the tiller.
I knew the tiller weighs in at around 500 lbs, so I picked up four 3" wheels, each rated at 225 lbs. These I fastened to two 2x8's each at 2 1/2' long. Then I boxed in the 2x8 with 2x4's creating the rectangle needed. I reinforced the inside of the 2x8 with a second 2x4 on each end. So it looks like a big open rectangle with the ends heavily reinforced, since that is where all the weight sits.
To keep the tiller from tipping forward or backwards, I anchored it to the dolly with a rachet strap. Despite the fact that it sits of skids, it has a tendency to tip, even if sitting on the floor.
It works quite well. I'm pleased with it for a first attempt, but I now think that larger wheels would have been better. These roll easily enough. However, they are a little stiff when spinning the tiller around to be rolled in a new direction.
So when I start on my next, I'll try the 4 or maybe even 5" wheels.
I'm hooked on this. I had to hook up the tiller, unhook, and roll it away several times just for the joy of it. No more snatching, kicking, or rocking the tractor.
   / Equipment Dolly #3
I made dollies for all my attachments as well. I used 5" urethane swivel casters each rated for 350lbs. Some dollies have more wheels than others, depending on the weight and configuration of the attachment.
I used leftover lumber from my deck project. Like yours, All the dollies are basically rectangles made from bolted together 2x boards.
Not only does it make it easy to move them around in my workshop, it also makes hookup/attachment easier. If I'm not quite lined up with the 3PH, I simply move the dolly!
   / Equipment Dolly
No pictures yet. Just finished the first today, so I will probably change before I'm satisfied with it. Went and looked at it again. I might just pull off those 3" casters tomorrow and try some 5". I'm going to have to buy new ones for the next project anyway, and I believe the 3" are just too small. I'm not satisfied. They are rather stiff. I'll get pics in a day or two after I've had time to sleep on it and revise. That's when I do my best thinking.
   / Equipment Dolly #5
I have dollies for every piece of equipment I own, from the backhoe down to the rear blade, including the loader. The only thing I didn't bother with is the rear finish mower, since its already on 4 wheels. Its absolutely amazing how easy it is to hook everything up. I had considered a quick hitch and also Pat's. With dollies, I have no need for either.
   / Equipment Dolly
Went with the 5 inch casters. Rolls very easily. I'd say they are worth the extra money.
2016 WESTERN STAR 5700XE TANDEM AXLE SLEEPER (A52577)
2016 WESTERN STAR...
New/Unused 78in Quick Attach Grass Fork Grapple (A51573)
New/Unused 78in...
2011 Ford F-350 Service Truck (A51692)
2011 Ford F-350...
New/Unused Quick Attach Auger with Three Bits (A51573)
New/Unused Quick...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
