EP Moly Grease, where do you buy yours?
   / EP Moly Grease, where do you buy yours? #1
botayota
CT River Valley - NH
Kubota L3240Hst
L3240 manual mentions use EP molybenum grease for the fittings, but
where do you find such a grease?
BY
   / EP Moly Grease, where do you buy yours? #2
Pretty much anywhere that sells grease will have EP (Extreme Pressure) moly (additive) grease, i.e. autozone, tractor supply. Everyone has their preference and what they think is best, but better to have cheap grease than no grease at all. On my B7510 I have used Valvoline Grease (labeled as being approved for Ford, is EP rated and contains moly) and some Mystik JT-6 (????) that is EP rated and contains moly. I think all/most of the EP rated grease I have seen with moly added has been gray in color.
I'll keep checking around to see if any of the local places have it.
Tnxs BY
   / EP Moly Grease, where do you buy yours? #4
Our local Walmart has it and so does Tractor Supply, Auto Zone & NAPA.
Walmart here has some weird brand, not sure it's ep moly, but probably is, I'll check there tomorrow, better grease than no grease:D
Tnxs!!!
   / EP Moly Grease, where do you buy yours? #6
Tnxs!!!
In an EP (extreme pressure) grease, the soap suspension is stiff to keep the grease from extruding away under load. "Moly" grease contains molybdenum disulfide (MoS2) which forms little spheroids - like tiny ball bearings - so real moly grease is very slippery. High MoS2 content is more effective than the EP suspensions - but makes for an expensive grease. Genuine Molykote (now a Dow Corning product) is around $20 for a small tube. So its more common to find regular EP greases with a small amount of MoS2 added so they can call them "Moly".
2022 Caterpillar 259D3 (A53317)
2022 Caterpillar...
INGERSOLL RAND SD-100D SMOOTH DRUM ROLLER (A52707)
INGERSOLL RAND...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
UNUSED FUTURE FT-X39 39" HYD TRENCHER (A57193)
UNUSED FUTURE...
2005 Autocar WXR T/A Heil 28Yd Side Loader Garbage Truck (A55852)
2005 Autocar WXR...
2016 Ford Taurus AWD Sedan (A55853)
2016 Ford Taurus...
