Entry step
   / Entry step #1
metalbender
Veteran Member
Sask, Canada
Massey 1742
Just a heads up on a problem that popped up on my 1742 cabbed model. Being a heavy guy, there's lots of stress on the step bolts. Had the front bolt snap. The resulting flex makes for nervous entry and exit till it's repaired. Having the step fail could cause some serious hurt. The broken part of the bolt came out easy with the drill rotation. Welded nuts are behind as there is no room above the tank. My suggestion is to get some better quality 8mm bolts to replace the existing spaghetti bolts.
   / Entry step #2
I do mostly forest work with my 1735M and ran my step into a tree sump. The step bent back into the tire and rubbed for about 100' before I noticed the strange noise. I removed all three, intact, bolts, hammered it back into shape, painted it sparkly blue to remind me not to do that again and bolted it back up.
FYI
A grade 2 bolt will shear at 8Kn or ~5800ft-lb
A grade 5 bolt will shear at 16Kn or ~11800ft-lb
Pretty sure you are not that big. More likely just a defective fastener that got missed.
2017 Makita HM1307CB 35lb Demolition Hammer (A49461)
2017 Makita...
2014 STEPHENS 200BBL TANKER TRAILER (A50854)
2014 STEPHENS...
TMA (A49461)
TMA (A49461)
2016 CHEVROLET SILVERADO 2500 HD CREW CAB TRUCK (A51243)
2016 CHEVROLET...
2022 FORD F-150 LARIAT CREW CAB TRUCK (A51406)
2022 FORD F-150...
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A49461)
2003 Big Tex 10PI...
