Engine Won't Turn Over
   / Engine Won't Turn Over #1
papa51
Mahindra 2816 4wd
Been working my 2816 regularly on my horse farm. Went out to start it this morning, turned the key on to let the glow plugs heat up, tried to start it and it just ground over a time or two and stopped. Hooked up the jumper cables and don't get a grunt. Checked the tractor battery and it's showing 12+ volts but no volts at solenoid. In fact, it shows a negative read out there. When I turn the key on there is a clicking sound behind the dash near the switch. Had a similar problem this summer and replaced the solenoid with a new one. Anybody know if there is a relay behind the dash that would be faulty?? Or any other ideas? Really need to get this thing running as I have a LOT of work I need to do.
Thanks,
C Slaughter:confused2:
   / Engine Won't Turn Over #2
Thanks,
I would check that all the connections are clean and tight. A fully charged battery should read about 13.5 volts. :thumbsup:
Thanks, Randall. I did that first thing. Even took the ground loose and removed the paint so it's metal to metal contact when I re-installed it. Battery posts are clean and tight, as are the contact nuts on the starter / solenoid. I also checked the safety switches on the pto and the gear shift. Guess I'll have to start at the positive cable and try to run it out connection by connection. Talked to a service man at a local dealer and he didn't understand why the dash lights won't come on when I hook it up to a running truck via jumper cables unless there is some sort of short or fuse issue. I'll try to check that in the morning.
Cliff S.
   / Engine Won't Turn Over #4
How old is the battery? It may be bad?
Even if the battery is bad shouldn't it have turned over when I hooked the jumper cables up to it, or at least the dash lights come on??
   / Engine Won't Turn Over #6
I'd say it's either the switch itself or a bad ground. Hook the positive jumper to the positive side of the battery and hook the negative side to the engine itself. I'm curious.
Will do, Dbellrn. I'm thinking the switch but I'll try the jumper cable hookup. I'm also going to take the battery and have it tested by a pro. All I have is a cheap meter that came from Auto Zone. It'll be Friday before I have a chance. I'll be on the road tomorrow. I'll post the results. Thanks for your input.
Cs
   / Engine Won't Turn Over #8
If you cleaned all cabels you might want to make sure all cabels are good. I had the same problem with my Kubota, it turned out the cabels were bad. Replaced them tractor fired right up. Jim
Great advice, Jim. I just came in from my morning feeding and pulling the battery to have it checked by a professional. I noticed the ground cable does indeed look suspicious so I'm also planning on replacing it. I guess I might as well go ahead and get the positive one while I'm at the dealership. As you know, there are few things more aggravating than needing your tractor and it not start. I might go ahead and pull the switch and have it checked for continuity also. I'll post whatever I found was the problem. Thanks, again.
   / Engine Won't Turn Over #10
My money is on a bad battery......:thumbsup:
New Holland 273 Hayliner Square Baler (A50515)
New Holland 273...
2019 Ford F550 4x4 Bucket Truck with Altec AT41 Boom - 46FT Working Height and Jib Winch (A52128)
2019 Ford F550 4x4...
2022 New Holland Workmaster 120 MFWD Compact Utility Tractor (A52128)
2022 New Holland...
Homemade Water Trailer 1100-gallon tank (A52128)
Homemade Water...
2017 CATERPILLAR 304E2 EXCAVATOR (A51242)
2017 CATERPILLAR...
UNUSED JCT SKID STEER QUICK ATTACH HAYSPEAR (A51244)
UNUSED JCT SKID...
