Engine Temperature
   / Engine Temperature #1
Hondo1
Western NY
YM1300D
Can anyone tell me, now that I have installed a water temperature gauge what temperature my YM1300D should run at? At what temperature should I shut it down?
Thanks again in advance.
Hondo
   / Engine Temperature #2
I think the I&T shop manual says the warning light comes on at 247 degrees.
Assuming you are using the standard 30% antifreeze and 13 psi cap, I suggest look up the boiling point for that combination and stay a safe margin below it.
   / Engine Temperature #3
I have a 1500 so I guess it runs about the same temp. I believe the 1300 also has no water pump. At idle mine usually hangs at about 160 range on days that are 80 degrees (outside temp doesn't really change things until it gets HOT out). When it works hard it easily goes to 200-210...but at that point I usually downshift and let it get a bit cooler (probably excessive on my part). I believe the high temp warning light is set to come on at 235 degrees...but let someone else verify that to make sure I am not way off base.
I use my 1500 for pulling gang mowers so I can always down shift...I may go slower but the engine revs faster and works easier so it cools down really fast. I also have almost pure distilled water in the radiator for warm weather use ...antifreeze will make the thermosiphon system run a lot hotter since it doesn't circulate as well.
Before I shut down I let it idle back to about 160 degrees...I hope that's the right thing to do.
By the way, my oils pressure runs about 45 when cold and revved over 1000 RPM. When fully hot and idling it goes down to about 20.
Hope this helps...and please let others verify my info. I can tell you what mine does...but others may tell you what it SHOULD do!
Peter
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
CATALOG UPDATES (A53084)
CATALOG UPDATES...
2005 GENIE Z-45/25 TELESCOPIC LIFT (A51246)
2005 GENIE Z-45/25...
TAYLOR TDF-60S STRAIGHT MAST FORKLIFT (A51246)
TAYLOR TDF-60S...
2009 Caterpillar 279C High Flow Compact Track Loader Skid Steer (A51691)
2009 Caterpillar...
Baker BFD80 8,000lbs Diesel Forklift (A51691)
Baker BFD80...
