Engine temp?
   / Engine temp? #1
Toyboy
Platinum Member
Hayward Wi
Kubota BX2230D
I've always thought my BX2230 was running cool and today after blowing snow for about 1 hour I finally checked it. The laser temp gun read 174 deg on engine and 145 on top of radiator. Being this is my first diesel that seems cool. Whats your thoughts on this?
   / Engine temp? #2
What is your ambient, obviously below freezing? I imagine your thermostat full open temperature is 190F. You should have 190F just below your thermostat housing. Disreguard the top tank temp in these cold climates, most of your coolant is probably running in bypass as controlled by the thermostat. You temp gun is taking a surface temp and not an internal temp reading, so I would say your 174F surface temp means your block has reached operating temperature and is running correctly. Philip.
   / Engine temp? #3
My 4240 runs at four (out of 8) bars on the display. I know diesel run cold, that's why you'll see school buses with the radiator partly covered in the winter to help raise the temp otherwise the kids would freeze.
   / Engine temp?
OK, Thanks. We're 25 deg here today. My temp gauge never moves more than 1/3 up the scale even in summer when a lot of guys are talking about theirs running hot. Oh well, good circulation I guess.
JOHN DEERE 8410T TRACTOR (A51243)
JOHN DEERE 8410T...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
CATALOG IS A GUIDE ONLY!! (A50774)
CATALOG IS A GUIDE...
LIGHT BAR AND WIRING (A50854)
LIGHT BAR AND...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
