Engine swap, good or bad?
   / Engine swap, good or bad? #1
tom4018
South Central Ky
Kubota M7040HD
20 hp Briggs twin cylinder is trashed but found some new 17.5 hp Briggs single cylinder for a good price. Will it pull a 46" mower deck ok? Looks like it will fit but will have to modify the hood for exhaust. Just wondering if I will be happy power wise. Trying not to have to go in debt to buy a mower.
   / Engine swap, good or bad? #2
If it physically fits, it'll work fine. Obviously, you won't have quite the power, so you may need to mow a bit slower. Most mowers are really overpowered anyway...
Mike
   / Engine swap, good or bad? #3
It will probably do the job, but I think you'll find a single cylinder a big disappointment after having a twin.
   / Engine swap, good or bad? #4
How bad is the 20? You can get a 'shortblock', basically a new engine minus all the externals & just move over your ignition, induction and tins. That's alot cheaper than buying a whole new engine. A few years ago I shortblocked my friend's Simplicity w/ 11hp B & S for $300 while they wanted close to $700.00 for a complete, ready to bolt on new engine.
OTOH 3 hp isn't all that much but you will notice a difference in torque VRS a twin, if youare the patient type you should be fine. My buddies 11hp w/ bagger was the same tractor as my sisters 8hp w/ no bagger.
   / Engine swap, good or bad? #5
Even if you have a single and a twin rated at the same HP, the twin will perform better under load. Torque for the twin will be more even over the single per revolution of the engine.
2012 Ford F-250 Pickup Truck (A52377)
2012 Ford F-250...
2014 Bomag BW900-S50 (A47477)
2014 Bomag...
2017 Ford F-550 Enclosed Service Truck (A53422)
2017 Ford F-550...
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A51692)
2014 Peterbilt 384...
2006 INTERNATIONAL 4300 DT466 SBA 4X2 BUCKET TRUCK (A51406)
2006 INTERNATIONAL...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A54607)
2015 VOLVO VNL...
