Engine starts cutting out after engaging mower deck
   / Engine starts cutting out after engaging mower deck #1
Marko
Derry , NH
2002 JD4110 HST
Hey folks,
I have a strange one here. I have a 1999 White (MTD) LT15 lawn tractor. I am having issues when lower / engaging the mower deck and having the engine start cutting out. If I raise the deck lever all the way (which stops the blades) the engine runs fine. I had the snowblower attachment in it this winter and did not have this issue when using the engagement lever to engage the auger. Tractor starts and runs great however the only issue is no matter what deck height I set the deck to , once I start engaging it the engines starts to quit. It first sounding like the deck safety switch was bad , so I replaced it with a new one. still no luck. I sprayed all electrical connections with electrical cleaner , still nothing. Though it might be a bade ground however outside of the battery ground could not find an other grounds. Why is this happening with the mower deck and not with the snowblower attachment. I am trying to bag my leaves and can not get the tractor to run with the mower deck engaged.
Help ! I do not want to rake :)
Mark
   / Engine starts cutting out after engaging mower deck #2
Do all of your blades rotate freely? If one of your spindles is sticking, it would create excess load on the engine and cause it to die. Will the engine run at lower RPMs and/or with partial choke?
It's a lot of work, but you could also try switching back to the snowblower to see if it fails under load with that attachment, now, too. You don't indicate whether it worked at all with the mower deck on this summer.
You could also try disconnecting the kill wire from the coil. If that fixes it, you have a bad ground somewhere. Please note that disconnecting that wire means the key will *NOT* stop your engine when you turn it off, so have another means of stopping it (fuel shutoff works eventually).
-rus-
Hey Rus ,
Yes both blades spin freely , the mower deck did this same thing last summer also however thought it was related to the safety switch. Snowblower attachment worked great all winter with no issues. Wouldn't a bad ground cause the same behavior with the snowblower attachment ? The tractor does not have a fuel shutoff , so If I test the kill wire option I'll have to install a fuel shutoff.
Mark
   / Engine starts cutting out after engaging mower deck #4
Does your tractor normally kill the engine when you put it in reverse with the PTO engaged? If so, check the reverse engagement switch that should be near the base of the shift lever.
There should be a wire that kills the ignition, and another that powers the fuel shutoff solenoid if your engine has one. If you can locate the ignition kill wire try disconnecting it to test, you can always reconnect it to stop the engine.
Yes , the tractor has the reverse with the PTO / mower deck engaged safety switch. There is also a solenoid on the bottom of the carb.
So is the test disconnecting the kill wire on the coil. If the behavior goes away this would suggest a bad ground somewhere. If so is there a common place on these tractors for the ground ?
Mark
   / Engine starts cutting out after engaging mower deck #6
Why would you think it's a bad ground? The ground seems to be working quite nicely to kill the engine. Look closely at the reverse switch, they can be pretty beat up. Same with the seat switch. I know you replaced your seat switch, but I'll bet your problem is somewhere between the reverse switch and the seat switch.
Both reverse and seat switches are clean and working correctly as when the mower deck is NOT engaged and the tractor is running fine , putting the tractor in reverse kills the engine and getting off the seat does the same thing. If these switches were the issue , I would think the same behavior would happen when using the engagement lever to engage the auger with the snowblower attachment , however this is not the case. The snowblower attachment works just fine. What is different between when the mower deck is engaged and the snowblower attachment ? What I have noticed is that this behavior will sometimes go away if I adjust the mower deck with the engagement lever and completely clears itself up with the lever is fully disengaged. This is very strange. I checked the clutch safety switch as well and that is working just fine. Tested this by leaving the tractor in gear without depressing the clutch petal. Tractor would not start and the light on the dash showing the foot brake lights up.
   / Engine starts cutting out after engaging mower deck #8
check clutch wiring for short; bare wires, etc. that might be causing problem. wiggle wires to see if you can get it to act up.
Check all linkages that mower attaches to tractor, looking for interference with wires.\
How is relay for pto clutch? mower may cause more amp load on relay than blower.
This tractor does not have an electric PTO , it has a manual engagement lever that engages the belt. So no electric relay involved here.
   / Engine starts cutting out after engaging mower deck #10
What about the possibility of something engine related? Poor gas, needs new plugs, water in the fuel bowl, engine needs tune up, partially plugged fuel jet etc.?
2018 Chevrolet Silverado 3500HD 4x4 Crew Cab 9FT Flatbed Truck (A51692)
2018 Chevrolet...
2003 McCormick XTX 185 XtraSpeed Tractor (A55218)
2003 McCormick XTX...
2012 Cadillac SRX SUV (A53424)
2012 Cadillac SRX...
2018 Suzuki KingQuad 750 AXi 4x4 ATV (A51691)
2018 Suzuki...
2017 Chevrolet Tahoe SUV (A52377)
2017 Chevrolet...
